Openhabian, Myopenhab high internet consumption
I use an LTE modem to connect to my openHAB remotely via myopenHAB. As I can see, the consumption is so high that my data limit is reached every month.
How can I check the consumption of myopenHAB or determine what consumes the most to reduce the data rate?
Please do not double post. You have already started a topic with the nearly the same question.
OK, sorry, for me these are two topics. First, why there is no myopenhab connection when the bandwidth is reduced, and the other question is how I can find out why I have such high consumption through openhabian/myopenhab.
So then i will post it in the other topic.
