Good Morning,
I use openhabian and OH2.1 on a raspberry pi 3 B.
For the second time I can not access either the SSH or OpenHab (8080) on the system. Ping goes however. Two days ago I noticed that already. Always so around 6/7 clock when our son woke us up the system does not work. The last time I had to work and in the evening ran again everything. Before I now the PI hard reboote I wanted to get rid of a few questions:
Is there a kind of resting state? How do I wake the PI?
Could the Amanda backup lie? Where do I see when this is done? How long does it take? My memory card has 32GB and it should be secured over LAN on a NAS (although the folders (slot1-3) until now are empty. I had configured the backup via openhabian-config three days ago …
Which logs should I look after a hard reboot? (I am a Linux beginner …)
How long would you wait before your system reboots hard?
Thank you
Oki I could not wait for an answere At home, there are too many everyday scenes on the server
After hardreset:
2017-07-01 04:30:00.351 [INFO ] [e.smarthome.model.script.Luftfeuchte] - TempK: 21.7 LuftK: 69.2 MittelwA: 17 LuftA: 81.00
2017-07-01 04:30:00.365 [INFO ] [e.smarthome.model.script.Luftfeuchte] - Abs. Luftfeuchte - in: 13.20081822668095 g/m3, out: 11.720773167605614 g/m3 dif: 1.480045059075336
2017-07-01 04:33:00.324 [INFO ] [Manager$ExpressionThreadPoolExecutor] - Expression '0 33 4 1 7 ? 2017' has no future executions anymore
2017-07-01 04:33:00.339 [INFO ] [Manager$ExpressionThreadPoolExecutor] - Expression '0 33 4 1 7 ? 2017' has no future executions anymore
2017-07-01 04:33:00.360 [INFO ] [Manager$ExpressionThreadPoolExecutor] - Expression '0 33 4 1 7 ? 2017' has no future executions anymore
2017-07-01 04:33:00.375 [INFO ] [Manager$ExpressionThreadPoolExecutor] - Expression '0 33 4 1 7 ? 2017' has no future executions anymore
2017-07-01 04:33:00.399 [INFO ] [Manager$ExpressionThreadPoolExecutor] - Expression '0 33 4 1 7 ? 2017' has no future executions anymore
2017-07-01 05:00:00.346 [INFO ] [e.smarthome.model.script.Luftfeuchte] - TempK: 21.7 LuftK: 69.2 MittelwA: 17 LuftA: 80.00
2017-07-01 05:00:00.362 [INFO ] [e.smarthome.model.script.Luftfeuchte] - Abs. Luftfeuchte - in: 13.20081822668095 g/m3, out: 11.576072264301843 g/m3 dif: 1.624745962379107
2017-07-01 08:53:51.335 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.166:8080
2017-07-01 08:53:51.353 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.166:8443
The empty line I can not copy. So here’s a screenshot:
Which logs in the system should I look at?
Tonight the log ends at 3:30 am … I had to restart the server again hard. Has no one idea?
So according to the WWW Is the syslog decisive …
The last line befor the crash is: “dhcpcd[633]: eth0: no IPv6 Routers available”
Gestern:
Jul 1 05:17:12 JBHome ntpd[866]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Jul 1 05:17:12 JBHome systemd[1]: Started LSB: Start NTP daemon.
Jul 1 05:17:12 JBHome ntpd[866]: Listen and drop on 1 v6wildcard :: UDP 123
Jul 1 05:17:12 JBHome ntpd[866]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jul 1 05:17:12 JBHome ntpd[866]: Listen normally on 3 eth0 192.168.1.166 UDP 123
Jul 1 05:17:12 JBHome ntpd[866]: Listen normally on 4 eth0 fe80::23d0:3c47:15be:c5c2 UDP 123
Jul 1 05:17:12 JBHome ntpd[866]: Listen normally on 5 lo ::1 UDP 123
Jul 1 05:17:12 JBHome ntpd[866]: peers refreshed
Jul 1 05:17:12 JBHome ntpd[866]: Listening on routing socket on fd #22 for interface updates
Jul 1 05:17:12 JBHome dphys-swapfile[769]: done.
Jul 1 05:17:12 JBHome kernel: [ 14.267164] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:200700k SSFS
Jul 1 05:17:12 JBHome systemd[1]: Started LSB: Autogenerate and use a swap file.
Jul 1 05:17:14 JBHome exim4[768]: Starting MTA: exim4.
Jul 1 05:17:14 JBHome systemd[1]: Started LSB: exim Mail Transport Agent.
Jul 1 05:17:16 JBHome systemd[1]: Started LSB: start Samba daemons for the AD DC.
Jul 1 05:17:16 JBHome nmbd[772]: Starting NetBIOS name server: nmbd.
Jul 1 05:17:16 JBHome systemd[1]: Started LSB: start Samba NetBIOS nameserver (nmbd).
Jul 1 05:17:16 JBHome systemd[1]: Starting LSB: start Samba SMB/CIFS daemon (smbd)...
Jul 1 05:17:18 JBHome smbd[1154]: Starting SMB/CIFS daemon: smbd.
Jul 1 05:17:18 JBHome systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Jul 1 05:17:18 JBHome systemd[1]: Starting Multi-User System.
Jul 1 05:17:18 JBHome systemd[1]: Reached target Multi-User System.
Jul 1 05:17:18 JBHome systemd[1]: Starting Graphical Interface.
Jul 1 05:17:18 JBHome systemd[1]: Reached target Graphical Interface.
Jul 1 05:17:18 JBHome systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jul 1 05:17:18 JBHome systemd[1]: Started Update UTMP about System Runlevel Changes.
Jul 1 05:17:18 JBHome systemd[1]: Startup finished in 1.520s (kernel) + 18.389s (userspace) = 19.910s.
Jul 1 05:17:19 JBHome dhcpcd[633]: eth0: no IPv6 Routers available
Jul 1 08:53:35 JBHome systemd[1]: Time has been changed
Jul 1 08:54:37 JBHome kernel: [ 83.317373] random: crng init done
Heute:
Jul 2 03:17:13 JBHome ntpd[839]: Listen normally on 2 lo 127.0.0.1 UDP 123
Jul 2 03:17:13 JBHome ntpd[839]: Listen normally on 3 eth0 192.168.1.166 UDP 123
Jul 2 03:17:13 JBHome ntpd[839]: Listen normally on 4 eth0 fe80::23d0:3c47:15be:c5c2 UDP 123
Jul 2 03:17:13 JBHome ntpd[839]: Listen normally on 5 lo ::1 UDP 123
Jul 2 03:17:13 JBHome ntpd[839]: peers refreshed
Jul 2 03:17:13 JBHome ntpd[839]: Listening on routing socket on fd #22 for interface updates
Jul 2 03:17:13 JBHome systemd[1]: Started LSB: Start NTP daemon.
Jul 2 03:17:13 JBHome systemd[1]: Received SIGRTMIN+21 from PID 252 (plymouthd).
Jul 2 03:17:13 JBHome systemd[1]: Started Hold until boot process finishes up.
Jul 2 03:17:13 JBHome systemd[1]: Started Terminate Plymouth Boot Screen.
Jul 2 03:17:13 JBHome ntp[775]: Starting NTP server: ntpd.
Jul 2 03:17:13 JBHome dphys-swapfile[772]: want /var/swap=100MByte, checking existing: keeping it
Jul 2 03:17:13 JBHome systemd[1]: Starting Getty on tty1...
Jul 2 03:17:13 JBHome systemd[1]: Started Getty on tty1.
Jul 2 03:17:13 JBHome systemd[1]: Starting Login Prompts.
Jul 2 03:17:13 JBHome systemd[1]: Reached target Login Prompts.
Jul 2 03:17:13 JBHome kernel: [ 15.191408] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:200700k SSFS
Jul 2 03:17:13 JBHome dphys-swapfile[772]: done.
Jul 2 03:17:13 JBHome systemd[1]: Started LSB: Autogenerate and use a swap file.
Jul 2 03:17:14 JBHome exim4[770]: Starting MTA: exim4.
Jul 2 03:17:14 JBHome systemd[1]: Started LSB: exim Mail Transport Agent.
Jul 2 03:17:16 JBHome systemd[1]: Started LSB: start Samba daemons for the AD DC.
Jul 2 03:17:17 JBHome nmbd[774]: Starting NetBIOS name server: nmbd.
Jul 2 03:17:17 JBHome systemd[1]: Started LSB: start Samba NetBIOS nameserver (nmbd).
Jul 2 03:17:17 JBHome systemd[1]: Starting LSB: start Samba SMB/CIFS daemon (smbd)...
Jul 2 03:17:18 JBHome systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Jul 2 03:17:18 JBHome systemd[1]: Starting Multi-User System.
Jul 2 03:17:18 JBHome systemd[1]: Reached target Multi-User System.
Jul 2 03:17:18 JBHome systemd[1]: Starting Graphical Interface.
Jul 2 03:17:18 JBHome systemd[1]: Reached target Graphical Interface.
Jul 2 03:17:18 JBHome systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jul 2 03:17:18 JBHome smbd[1158]: Starting SMB/CIFS daemon: smbd.
Jul 2 03:17:18 JBHome systemd[1]: Started Update UTMP about System Runlevel Changes.
Jul 2 03:17:18 JBHome systemd[1]: Startup finished in 1.717s (kernel) + 18.646s (userspace) = 20.363s.
Jul 2 03:17:19 JBHome dhcpcd[633]: eth0: no IPv6 Routers available
Jul 2 10:58:17 JBHome systemd[1]: Time has been changed
Jul 2 10:58:56 JBHome kernel: [ 60.809208] random: crng init done
Does anyone have an idea what my problem is?
var/log/messages:
Jul 1 05:17:11 JBHome kernel: [ 13.350791] FS-Cache: Netfs 'cifs' registered for caching
Jul 1 05:17:11 JBHome kernel: [ 13.351594] Key type cifs.spnego registered
Jul 1 05:17:11 JBHome kernel: [ 13.351623] Key type cifs.idmap registered
Jul 2 03:17:11 JBHome kernel: [ 13.493566] FS-Cache: Netfs 'cifs' registered for caching
Jul 2 03:17:11 JBHome kernel: [ 13.494393] Key type cifs.spnego registered
Jul 2 03:17:11 JBHome kernel: [ 13.494427] Key type cifs.idmap registered
sihui
(SiHui)
July 2, 2017, 10:47am
6
Bad sd card? Bad power supply?
Thanks for the hint.
I ordered a new and recommended power supply now: “Wicked Chili 3100mA / 15.5W for Raspberry Pi 3 B”. I will test it the next days.
The “SanDisk Ultra Android microSDHC 32GB” is a new one. I hope that one is not the problem… Is there a way to test it?
Can it also be the PI itself?
I am confused that the crashes take place always at a similar time in the morning.
Solution:
Yesterday I have uninstalled amanda backup with:
sudo apt-get purge --auto-remove amanda-server
sudo apt-get purge --auto-remove amanda-client
No more freeze/hold today
sihui
(SiHui)
July 3, 2017, 10:42am
9
This should be watched closely if that happens on other systems, too. @mstormi ?
mstormi
(Markus Storm)
July 3, 2017, 11:48am
10
Well, it’s unlikely to be related to Amanda itself.
But if your backup is too large or you stress the SD card too much or Pi I/O or even the NAS I/O altogether, this can lead to lockups (temporary or permanent) like what you observed.
Actually, to backup a 32GB disk is possibly just too much (never thought anyone would use such a big one, I thought my own 16GB is already way to large).
My suggestion would be to re-install Amanda but to remove the raw ‘disk’ backup (remove the /dev/mmcblk0
line from /etc/amanda/openhab-dir/disklist
) so Amanda will only backup the (way smaller) config directories.
To answer your question, Amanda is started from /etc/cron.d/amanda at 01:00 by default, but you can remove or change that entry and you can manually initiate it running 'amdump '.
Note you need to be the ‘backup’ user, so actually it’s sudo su - backup -c "amdump openhab-dir"
PS: eventually you could enable the now commented-out holding disk in /etc/amanda/openhab-dir/amanda.conf
(make sure you insert a NAS-mounted directory name to the ‘directory’ line) , that would segment the big dump into multiple smaller segments (as large as the holding disk size definition).
Thank you for that information. I am using a 32GB SD because it is cheap
Because I am not that good in debugging with linux, I am happy to ceep my system stabel. Due to that I will beackup the files by using the official recommandation for now:
sudo systemctl stop openhab2.service
BACKUPDIR="/mnt/JB-Data/JBHome/openhab2-backup/$(date +%Y%m%d_%H%M%S)"
mkdir -p $BACKUPDIR
cp -arv /etc/openhab2 "$BACKUPDIR/conf"
cp -arv /var/lib/openhab2 "$BACKUPDIR/userdata"
rm -rf "$BACKUPDIR/userdata/cache"
rm -rf "$BACKUPDIR/userdata/tmp"
sudo systemctl start openhab2.service
But anyway some more information to help you debugging:
My infrastructure:
TP-Link TL-SG1024DE
FritzBox 6490 Cable
Netzwerk Gigabit (1200 mhz)
Synology DS216j
//xxxx/xxxx /mnt/JB-Data/JBHome cifs username=xxxxx,password=yyyyy,file_mode=0777,dir_mode=0777 0 0
During the backup time (1am) I have no known traffic or disc I/O
During the configuration with openhabian-config --> Backup/Restore I remember some settings:
40GB
3 virtual folder or something like this
backup to nas
Apologize that I’m too cowardly, to install amanda again. I just have low Linux experience and I have to cheat on every error. That costs a lot of time.
What leads me to my next question…:
Is it useful to remove the remaining packages (see “The following packages will be REMOVED”)?
mstormi
(Markus Storm)
July 13, 2017, 8:14pm
12
FWIW, I’ve disabled SD backups per default now in openHABian. You can still enable it with an entry in the disklist
file.
