i run into this problem into my terminal window, can’t find any documentation to help me.
2020-08-25_22:38:11_EDT [openHABian] Checking for root privileges… OK
2020-08-25_22:38:11_EDT [openHABian] Installing whiptail… FAILED
The goal here is to use the HUSBZB-1 z-wave zigbee usb stick
from what I read I need to edit stuff into openhabian … well I can’t install openhabian.
OpenHab is installed.
I m just trying to use the Husbzb-1 zwave zigbee stick.
With the zigbee and zwave binding i should see it under port /dev/ttyUSB0
But i don t see the USB0 or USB1 … only see tty.bluetooth
