Openhabian + rasbery pie 3 -> no network and no rasberian:8080
I am new to openHAB, and to rasbery, and not an experienced linux user, so I hope that you will bear with me…
I have a rasbery pie 3 B with a RJ45 connection to my router.
I installed openhabian on a SD card using the rasbery pi imager, I booted the os on the rasbery (I have attached a screen to it to see what was happening)…
After the whole automatic install process (around 30 minutes I think) reboot ended and the processed seemed completed.
And here started the issues:
1: I seem to have no network connectivity on my rasbery (network LED are blinking), but no IP addresses, no ping…
I attached a keyboard, logged in and discovered that the NetworkManager is not running…
Starting NetworkManager manually, I can now ping my rasbery from other computers on my network…
I went through the openhabian-config (basically installing, and accepting basic options, as far as I can tell)… All seemed to have gone ok…
2: trying to open a browser to http://192.168.1.108:8080 results in a “connection failed”
Could you please help me get started?
Thanks,
Cyrille
Check logs under /var/log/openhab/ especially the openhab.log file.
