Openhabian reset by itself
I have a really crazy behaviour of my openhab installation.
As the topic already says, it restores an “old” version by itself. Everything works fine for approximately 3 months. But this problem came up three days ago, and i don’t know why.
There is no restart of openhab or something else. Suddenly it shows the full configuration of date 25.12.2017. All changes i have done the time between are gone. No matter what i change, if there are new item files, rules or something else. Every change works fine for approximately 1 or 2 hours and then there comes the “reset” and everything is at date 25.12.2017 and all changes are gone.
I am really confused and don’t know what to do.
What i’ve done till now:
  • installed all available updates and upgrades under sudo openhabian-config
    but also this upgrades are gone after the ownreset
There are no entries in Logfiles, even logfiles start again at 25.12.2017
Running openhabian 1.4 on a RPI3
Hope someone can solve my problem :frowning:
Sounds like you have a corrupted/defect SD card :frowning:
Did a sudo touch /forcefsck
It seems to be solved. Hopefully!
