I am a happy openHABian user since some weeks.
Now, I’d like to control my projector using the Epson binding and a usb-to-rs232 adapter. As a linux newbie, this is a bit challenging.
I went into the openHABian configuration and enabled menu 20 (serial port) by accident. As far as I understand, this was a mistake. How can I undo this?
In addition, the whole internet seems to talk about accessing serial devices in /etc/tty, which doesn’t exist in openHABian. I assume, I miss something?
So far, I managed to identify my usb cable using the command lsusb, which gave the following output:
Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The command ll /sys/class/tty/ttyUSB* returns
lrwxrwxrwx 1 root root 0 Dec 9 16:26 /sys/class/tty/ttyUSB0 → …/…/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0/
And the epsonprojector.cfg file has the entry:
beamerWohnen.serialPort=/sys/class/tty/ttyUSB0
Any hint about how I can proceed?
Thx, G.
