I’m struggeling with providing a virtual serial port to my openHABian installation.(snapshot #858).
Using socat I define e.g. /dev/ttyS5 or /dev/USB0. However the binding that should see the serial port (in this case the Comfoair binding) is always telling me it can not find the /dev provided in the config - although its there. Dialout and tty groups have been assigned to openhab user. I’m using a Razberry board on ttyAMA0.
Do I need to change anything to this one?
cat /etc/default/openhab2
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyAMA0:/dev/ttyS5"
Is there any other specific Pi3 or openHABian setting that needs to be set to enable other virtual serial ports?
Currently I do not think it’s the Comfoair binding, because what I’ve seen from other Comfoair users it can be connected to various serial ports - not limited to specific ones.
Would appreciate your thoughts here!
Bernd
