Openhabian starts itself on its own after openhab-cli stop
Hi everyone
I wanted too edit some item names these are well established already so i use vscode find and replace all and openhab has too be offline too do this but SMB shares still online
so i use the command sudo openhab-cli stop
this stops openhab from running but leaves the rest of my RPI online for editing but i have noticed that openhab is starting itself without me rebooting or running sudo openhab-cli start
is this normal behaviour its annoying if my system comes back online while editing files in this manner it does cause upset i nearly lost my setup last time this happened
2018-07-25 20:34:33.530 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-07-25 20:34:33.630 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-07-25 20:34:33.657 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2018-07-25 20:34:33.687 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-07-25 20:34:54.687 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-07-25 20:34:55.724 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/London'.
2018-07-25 20:34:55.741 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_GB'.
2018-07-25 20:34:55.744 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SIUnits'.
2018-07-25 20:34:57.731 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.94:8080
2018-07-25 20:34:57.737 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.94:8443
2018-07-25 20:34:58.377 [INFO ] [io.openhabcloud.internal.CloudClient
Why? No need for openHAB being stopped…
Can’t help with the autostart, not using openHABian (or apt-repo) :sunglasses:
It upsets the system if you change item names while it’s running I have done it a few times it does not like it
I mean a full system scan of every file and change any instance of the name in the logs in persistence everywhere it just doesent like it
Systemd is running openhab2 as a service and it makes sure that it is always running.
You need to tell systemd that you want the service stopped:
sudo systemctl stop openhab2
Use start to start it again and use status to see if it is started or stopped.
It does say something about that underneath but I thought it was stopped as I have used the status part before and it says stopped
I didn’t realise it worked like that :wink:
