- Platform information:
- Hardware: Rpi4/4g
- OS: openHABian Configuration Tool — [openHAB3]{2021-07-28T12:25:04+02:00}(1f4f1ce)
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 3.1.0
as my 2.5.x setup is slowly dying i tried to setup openHAB3 from the latest openHABian (1.6.5) with this openhabian.conf
hostname=ohab3
username=openhabian
userpw="openhabian"
adminkeyurl=""
timezone=Europe/Berlin
locales="en_US.UTF-8 de_DE.UTF-8"
system_default_locale="en_US.UTF-8"
wifi_ssid=""
wifi_password=""
wifi_country=""
ipv6=disable
repositoryurl=https://github.com/openhab/openhabian
clonebranch=main
debugmode=off
cached_java_opt=Zulu11-32
java_opt=Zulu11-32
zraminstall=enable
hotspot=enable
hotspotpw=openhabian
backupdrive=/dev/sda
storageconfig=openhab-dir
storagedir=/storage
storagetapes=15
storagecapacity=7168
adminmail=...
relayuser=...
relaypass=...
smarthost=smtp.gmail.com
smartport=587
as you can see i left debugmode=off
i changed only the parameters hostname, backupdrive, storagecapacity and the “mail-parameters”…
according to the chapter “Auto Backup” from the openhabian unattended installation section setting the backupdrive parameter should setup “disk mirroring PLUS the setup of the Amanda backup system”, right?
the mirroring should’ve worked, i got confirmation via mail:
A timed background job to run semiannually has just created a full raw device copy of your RPI’s internal SD card.
Only partitions to contain openHABian (/boot and / partitions 1 & 2) were copied.
but amanda wasn installed during unattended configuration. first-boot.log:
2021-03-04_23:04:50_UTC [openHABian] Starting the openHABian initial setup.
2021-03-04_23:04:51_UTC [openHABian] Storing configuration... OK
2021-03-04_23:04:51_UTC [openHABian] Starting webserver with installation log... OK
2021-03-04_23:04:56_UTC [openHABian] Changing default username and password... OK
2021-03-04_23:04:56_UTC [openHABian] Setting up Ethernet connection... OK
2021-03-04_23:04:56_UTC [openHABian] Ensuring network connectivity... OK
2021-03-04_23:04:56_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2021-07-29_11:45:57_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2021-07-29_11:45:57_UTC [openHABian] Installing git package... FAILED
2021-07-29_11:45:57_UTC [openHABian] Updating myself from https://github.com/openhab/openhabian, main branch... OK
2021-07-29_11:45:57_UTC [openHABian] Starting execution of 'openhabian-config unattended'... OK
2021-07-29_11:45:57_UTC [openHABian] Checking for root privileges... OK
2021-07-29_11:45:58_UTC [openHABian] Disabling IPv6... OK
2021-07-29_11:45:58_UTC [openHABian] Updating Linux package information... OK
2021-07-29_11:46:10_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-07-29_11:46:15_UTC [openHABian] Setting timezone based on openhabian.conf... OK (Europe/Berlin)
2021-07-29_13:46:15_CEST [openHABian] Enabling time synchronization using NTP... OK
2021-07-29_13:46:16_CEST [openHABian] Setting locale based on openhabian.conf... OK (reboot required)
2021-07-29_13:46:54_CEST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2021-07-29_13:46:54_CEST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2021-07-29_13:46:54_CEST [openHABian] Enabling Audio output... OK
2021-07-29_13:46:54_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2021-07-29_13:48:38_CEST [openHABian] Installing additional needed packages... OK
OK
2021-07-29_13:49:57_CEST [openHABian] Installing pigpio package... OK
2021-07-29_13:50:26_CEST [openHABian] Installing additional bluetooth packages... OK
2021-07-29_13:51:51_CEST [openHABian] Adding slightly tuned bash configuration files to system... OK
2021-07-29_13:51:51_CEST [openHABian] Adding slightly tuned vim configuration file to system... OK
2021-07-29_13:51:52_CEST [openHABian] tailscale VPN installation... SKIPPED (no preauthkey defined)
2021-07-29_13:51:52_CEST [openHABian] Applying miscellaneous system settings... OK
2021-07-29_13:51:52_CEST [openHABian] Downloading FireMotD... OK
2021-07-29_13:51:53_CEST [openHABian] Installing FireMotD... OK
2021-07-29_13:51:53_CEST [openHABian] Generating FireMotD theme... OK
2021-07-29_13:52:11_CEST [openHABian] Setting up FireMotD apt updates count service... OK
2021-07-29_13:52:25_CEST [openHABian] Installing cached version of Java to ensure that some form of Java is installed!
2021-07-29_13:52:25_CEST [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... OK
2021-07-29_13:52:25_CEST [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... OK
2021-07-29_13:52:26_CEST [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
2021-07-29_13:52:27_CEST [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)... OK
2021-07-29_13:52:27_CEST [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK... OK
2021-07-29_13:53:08_CEST [openHABian] Installing Java Zulu 11 32-Bit OpenJDK... OK
2021-07-29_13:53:11_CEST [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength... OK
2021-07-29_13:53:12_CEST [openHABian] Beginning install of latest openHAB3 release (stable)... OK
2021-07-29_13:53:12_CEST [openHABian] Adding required keys to apt... OK
2021-07-29_13:53:17_CEST [openHABian] Installing selected openHAB3 version... OK
2021-07-29_13:55:04_CEST [openHABian] Setting up openHAB service... OK
2021-07-29_13:55:05_CEST [openHABian] Optimizing openHAB to run on low memory single board computers... OK
2021-07-29_13:55:05_CEST [openHABian] Setting openHAB HTTP/HTTPS ports... OK
2021-07-29_13:55:05_CEST [openHABian] Creating dependencies to jointly start services that depend on each other... OK
2021-07-29_13:55:05_CEST [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... OK
2021-07-29_13:55:05_CEST [openHABian] Restarting openHAB service to play it safe... OK
2021-07-29_13:55:06_CEST [openHABian] Adding openHAB syntax to vim editor... OK
2021-07-29_13:55:07_CEST [openHABian] Adding openHAB syntax to nano editor... OK
2021-07-29_13:55:08_CEST [openHABian] Adding openHAB scheme to multitail... OK
2021-07-29_13:55:08_CEST [openHABian] Preparing openHAB folder mounts under '/srv/openhab-*'... OK
2021-07-29_13:55:16_CEST [openHABian] Installing Samba... OK
2021-07-29_13:58:05_CEST [openHABian] Setting up Samba network shares... OK
2021-07-29_13:58:10_CEST [openHABian] Setting up Samba service... OK
2021-07-29_13:58:12_CEST [openHABian] Installing Frontail prerequsites (NodeJS)... OK
2021-07-29_13:59:15_CEST [openHABian] Installing openHAB Log Viewer (frontail)... 2021-07-29_13:59:15_CEST [openHABian] Downloading frontail... OK
OK
2021-07-29_14:00:39_CEST [openHABian] Setting up openHAB Log Viewer (frontail) service... OK
2021-07-29_14:00:40_CEST [openHABian] Adding an openHAB dashboard tile for 'frontail'... OK
2021-07-29_14:00:40_CEST [openHABian] Installing zram... 2021-07-29_14:01:24_CEST [openHABian] Installing MTA required packages (mailutils, exim4, dnsutils)... OK
2021-07-29_14:03:18_CEST [openHABian] Setting up Mail Transfer Agent ... OK
2021-07-29_14:03:18_CEST [openHABian] Adding exim4 to zram service dependencies... OK
2021-07-29_14:03:19_CEST [openHABian] Creating MTA config... OK
2021-07-29_14:03:19_CEST [openHABian] Adding to [...] email to system accounts... OK
2021-07-29_14:03:19_CEST [openHABian] Applying file permissions recommendations... OK
2021-07-29_14:03:21_CEST [openHABian] Setting up automated SD mirroring and backup... OK
Failed to stop storage.mount: Unit storage.mount not loaded.
sfdisk: no disk device specified
Checking that no-one is using this disk right now ... OK
Disk /dev/sda: 14.9 GiB, 15931539456 bytes, 31116288 sectors
Disk model: Storage Device
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xc21ed95a
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 15523839 14991360 7.2G 83 Linux
/dev/sda3 15523840 31116287 15592448 7.4G 83 Linux
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0x8764e576.
/dev/sda1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 256 MiB.
Partition #1 contains a vfat signature.
/dev/sda2: Created a new partition 2 of type 'Linux' and of size 7.2 GiB.
Partition #2 contains a ext4 signature.
/dev/sda3: Created a new partition 3 of type 'Linux' and of size 7.4 GiB.
Partition #3 contains a ext4 signature.
/dev/sda4: Done.
New situation:
Disklabel type: dos
Disk identifier: 0x8764e576
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card
yes: standard output: Broken pipe
OK
OK
OK
2021-07-29_14:14:31_CEST [openHABian] Cleaning up... OK
2021-07-29_14:14:53_CEST [openHABian] Execution of 'openhabian-config unattended' completed.
2021-07-29_14:14:53_CEST [openHABian] First time setup successfully finished. Rebooting your system!
2021-07-29_14:14:53_CEST [openHABian] After rebooting the openHAB dashboard will be available at: http://openhabian:8080
2021-07-29_14:14:53_CEST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
the only error that could be relevant may be Installing git package... FAILED
but i have no idea which package…
as far as i can see there wasn’t even an attempt to install/configure amanda
the parameter storagecapacity=7168
is smaller than the free space on /dev/sda3/ :
openhabian@ohab3:~ $ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 14.9G 0 disk
├─sda1 8:1 1 256M 0 part
├─sda2 8:2 1 7.2G 0 part
└─sda3 8:3 1 7.4G 0 part /storage
mmcblk0 179:0 0 7.4G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 7.2G 0 part /
zram0 254:0 0 600M 0 disk [SWAP]
zram1 254:1 0 900M 0 disk /opt/zram/zram1
zram2 254:2 0 600M 0 disk /opt/zram/zram2
what did i wrong this time? i just changed 3 parameters
