I wanted to update from my OH 2.1 #928 snapshot to the latest release 2.1. So got the update to openhabian switched the repo channel etc. and hit “upgrade system”. I had about 40 apt-get updates open so far… after starting the upgrade I got this error message:
Fetched 104 MB in 1min 43s (1,000 kB/s)
[master c65f025] saving uncommitted changes in /etc prior to apt run
Author: pi <pi@openHABianPi>
1 file changed, 2 insertions(+), 1 deletion(-)
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 25354 files and directories currently installed.)
Preparing to unpack .../debconf_1.5.56+deb8u1_all.deb ...
Segmentation fault
dpkg: warning: subprocess old pre-removal script returned error exit status 139
dpkg: trying script from the new package instead ...
Segmentation fault
dpkg: error processing archive /var/cache/apt/archives/debconf_1.5.56+deb8u1_all.deb (--unpack):
subprocess new pre-removal script returned error exit status 139
Segmentation fault
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 139
Errors were encountered while processing:
Updating FireMotD available updates count ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
There is enough space on the SD and I tried with apt-get clean, autoremove and whatever I found regarding this error in other communities but without success.
I can not do any update to the system files or openhab currently
Did anyone experience a similar error with other packages maybe? What am I missing and how could I fix this?
Hello @bernd_d,
seems like there was a problem updating debconf. That’s one of many Linux packages and it’s unrelated to openHAB. You’d better search the Internet to find a solution. Good luck!!
Hi @ThomDietrich, you are right this is not directly related to openHAB but many users here are very experienced in Linux. The luck was not on my side so far but maybe on others here…
Also check /usr/bin/ for a file called dpkg. (make sure the executable is there)
Google says this:
"A segmentation fault (aka segfault) is a common condition that causes programs to crash; they are often associated with a file named core . Segfaults are caused by a program trying to read or write an illegal memory location.Nov 30, 2016
@Benjy, thank you for this additional hint. --configure runs into another error and the -i --force-overwrite runs into a similar error as originally posted…
The error of --configure -a is:
dpkg: error processing package debconf (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
debconf
As I have already backed up my files, I think I need to go the new install route…
I was not able to determine which deb package was corrupt.
The only think I am certain about is that SD card was not causing the issue.
sudo apt-get remove of openhab and openhab-addons followed by fresh install of main release did the trick.
