I noticed a error while trying to update my openhabian snapshot (master branch) from #142
The following packages will be upgraded:
openhab2
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 83.0 MB of archives.
After this operation, 0 B of additional disk space will be used.
Err:1 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main armhf openhab2 all 2.5.6~S143-1
Unknown date format Bad header data [IP: 35.231.52.82 443]
E: Failed to fetch https://openhab.jfrog.io/openhab/openhab-linuxpkg/pool/main/2.5.6~S143/openhab2_2.5.6~S143-1_all.deb Unknown date format Bad header data [IP: 35.231.52.82 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Is it just me or did someone else noticed that problem?
Should i run that command suggested in the last line?
That’s right, I will let you know as soon I think the problem is fixed. At this moment in time the repo should be working, but it’ll likely come up with the same error when a new snapshot comes out.
