- Platform information: Raspberry Pi 4 , 64bit
- openHAB version: openHABian 1.6.5
- Issue of the topic: after writing the image openHABian 1.6.5 to SD card using Etcher of Raspberry Pi Imager and install into Raspberry Pi , setup are not starting at all and can not see any IP address assigned to RaspberryPI in network scan while if i use openHABian 1.6.4 version everything goes fine with no issue.
Can you attach a monitor and check what you see there?
Can you run the official os on the PI ?
What lights come on
Which image did you use? 32bit or 64bit?
If it’s the second, please use the 32bit image:
I have used 64bit
But i just tried with 32bit and ut is working, thanks
