I am stuck overall almost a week by zwave binding in OH2. Using openhabianpi-ua-netinst-20170317-gitbd31755f-crc88a5ae46.img.
I have tried at least 10 different approaches but controller is still offline in openhab.
Tried:
disabling in openhabian-config options 1 (disable serial console) and 3(add common serial ports to OH JVM)
editing setenv file adding JAVA OPTS
changing access rights to /dev/ttyAMA0
openhab user is added in dialout even tty
serial-getty@ttyAMA0.service stopped or masked to /dev/null
enabled uart
installing liblockdev1-dev library
and maybe more…
When adding in HABMIN or PAPER UI i acan add zwave binding, i can set controller serial port to /dev/ttyAMA0 where it really is (from sytem log ) because it is properly loaded to system and openhab loads and initializes controller but next it just turns it offline and timeouts every request like in most of cases i saw.
Please tell me what to do, i am not totally amateur but not good in linux.
P.S.: My Zwave stick is properly working on my PC where I have Domoticz installed and it works without problems. But i want to switch it to rpi2.
[419952.705981] usb 1-1.4: new full-speed USB device number 6 using dwc_otg
[419952.809328] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200
[419952.809485] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[419952.811295] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
and
binding is only zwave(COM) milight(UDP) and ubiquiti (TCP)
is there anything that can block my controller or how could I find if it is online in linux not in openhab??
I am soooo stupid but i bet that I tried to configure ttyAMA annd ttyACM and ttyS0 and others… but now i see ACM and when I set up ttyACM0 and restarted openhab it started working. I don’t know if switching USB could change it but I don’t think so.
