a beginners one: Question 1: when I run OH backup through openhabian-config, the zip file does not contain my items in ...\openHAB-conf\items , rules, things… I was trying to find them in Samba fileshares, but it is also empty. Where are OH3 Items, Rules, Things and so on stored, when they are not there?
Question 2: how do I know, that mirroring of SD Card is active? I run it through openhabian-config, but I havent found any message, if it is succesfully started.
Tue 2021-02-02 02:00:00 CET 9h left Sat 2021-01-23 02:00:00 CET 1 weeks 2 days ago sdrsync.timer
Thu 2021-07-01 01:15:00 CEST 4 months 27 days left Fri 2021-01-22 23:41:34 CET 1 weeks 2 days ago sdrawcopy.timer
so the SD card is backed up every 10 days, right?
I have not received any email yet.
/etc/systemd/system/sdrawcopy.service. But you should be knowing what you do and I don’t think you want that.
Mind the second timer it is incremental only but runs daily. You can also start at any time using systemctl start sdrawcopy.service
ok, as a beginner, I will leave it as it is. I am making configuration backups, copying them to my NFS, hopefully it will be enough to bring system back in case of fails.
