I’m not sure what I’m missing, but I’m using 1.7.1, have configured openpaths with a 5 minute interval but when the system starts up there’s no update from openpaths (despite confirming that I can see updates on the openpaths site).
Binding:
############################### OpenPaths Binding #####################################
#### The latitude/longitude coordinates of 'home'.
# values modified below to protect privacy
openpaths:home.lat=45.xx
openpaths:home.long=-75.xx
openpaths:home.geofence=100m
# You may define any number of additional locations. If no geofence is given
# for a location, the default geofence configuration below is used
# The latitude/longitude coordinates of 'work'.
openpaths:work.lat=45.xx
openpaths:work.long=-75.xx
openpaths:work.geofence=100m
# The latitude/longitude coordinates of 'anyplace'.
#openpaths:anyplace.lat=
#openpaths:anyplace.long=
#openpaths:anyplace.geofence=
# Interval in milliseconds to poll for user location (optional, defaults to 5mins).
#openpaths:refresh=30000
# Distance in metres a user must be from 'home' to be considered inside the
# geofence (optional, defaults to 100m).
#openpaths:geofence=100m
# OpenPaths access/secret keys for each user.
openpaths:jf.accesskey=MY ACCESS KEY
openpaths:jf.secretkey=MY SECRET KEY
.items:
/** OpenPaths **/
Switch JFPresenceHome "J.F. @ Home" { openpaths="jf:home" }
Number JFHomeDistance "J.F. away from home: [%.2f km]" { openpaths="jf:home:distance" }
Switch JFPresenceWork "J.F. @ work" { openpaths="jf:work" }
Number JFWorkDistance "J.F. away from work: [%.2f km]" { openpaths="jf:work:distance" }
String JFPhone_currentLoc "J.F. current location: [%s]" { openpaths="jf:currentLocation" }
Number JFPhone_currentLat "J.F. latitude: [%.4f °]" { openpaths="jf:currentLatitude" }
Number JFPhone_currentLon "J.F. longitude: [%.4f °]" { openpaths="jf:currentLongitude" }
Sitemap:
Frame label="User Presence" icon="house" {
Switch item=JFPresenceHome
Switch item=JFPresenceWork
From the log (only instance of openpaths found):
10:16:32.079 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFPresenceHome (Type=SwitchItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.079 [INFO ] [.service.AbstractActiveService:169 ] - Nest Refresh Service has been started
10:16:32.313 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFHomeDistance (Type=NumberItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.344 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFPresenceWork (Type=SwitchItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.344 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFWorkDistance (Type=NumberItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.344 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFPhone_currentLoc (Type=StringItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.344 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFPhone_currentLat (Type=NumberItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
10:16:32.360 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'JFPhone_currentLon (Type=NumberItem, State=Uninitialized)' with 'OpenPathsGenericBindingProvider' reader.
Thanks for your help!
J.F.
