Hello
by error i installed OpenSenseNetwork Binding
first i thought it is about the firewall opnsense
no i can’t find it for uninstalling, so how to remove it from the Configuration - Bindings?
Hello
How did you install it in the first place? I did a quick check on OH2.5.0.M1 and this binding was not in the list AFAIKT. If you installed the .jar file manually in the addons folder, remove it from there.
BTW, which version of OH are you running?
openhab-cli info
Version: 2.4.0 (Build)
and found some more error
**# /bin/systemctl status openhab2.service**
? openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2019-03-26 22:09:28 CET; 1min 42s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 3884 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 4009 (java)
Tasks: 118 (limit: 4915)
CGroup: /system.slice/openhab2.service
mq4009 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dope
Mär 26 22:10:37 openhab-01 karaf[4009]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.j
Mär 26 22:10:37 openhab-01 karaf[4009]: at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(Fea
Mär 26 22:10:37 openhab-01 karaf[4009]: at java.util.concurrent.FutureTask.run(FutureTask.java:266)
Mär 26 22:10:37 openhab-01 karaf[4009]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
Mär 26 22:10:37 openhab-01 karaf[4009]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
Mär 26 22:10:37 openhab-01 karaf[4009]: at java.lang.Thread.run(Thread.java:748)
Mär 26 22:10:37 openhab-01 karaf[4009]: Caused by: org.osgi.framework.BundleException: Unsupported 'Bundle-ManifestVersion' value: 1
Mär 26 22:10:37 openhab-01 karaf[4009]: at org.apache.felix.utils.resource.ResourceBuilder.doBuild(ResourceBuilder.java:90)
Mär 26 22:10:37 openhab-01 karaf[4009]: at org.apache.felix.utils.resource.ResourceBuilder.build(ResourceBuilder.java:80)
