Hello
i’m using OH 1.8.2 with the OpenSprinkler ADDON.
But it doesn’t works.
Can someone help me to fix this problem?
Thanks in advance!
16:58:37.537 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'zwave.items’
16:58:40.817 [DEBUG] [o.b.o.i.OpenSprinklerActivator:34 ] - OpenSprinkler binding has been started
16:58:40.851 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_0 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
ingProvider’ reader.
16:58:40.859 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_1 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.863 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_2 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.870 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_3 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.876 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_4 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.881 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_5 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.887 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_6 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
16:58:40.892 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration
of Item ‘Sprinkler_Station_7 (Type=SwitchItem, State=Uninitialized)’ with ‘OpenSprinklerGenericBind
java.io.IOException: Cannot run program “bash”: CreateProcess error=2, Impossibile trovare il file s
pecificato
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at com.pi4j.util.ExecUtil.execute(ExecUtil.java:45)
at com.pi4j.util.ExecUtil.execute(ExecUtil.java:40)
at com.pi4j.system.SystemInfo.getBashVersionInfo(SystemInfo.java:441)
at com.pi4j.system.SystemInfo.access$000(SystemInfo.java:43)
at com.pi4j.system.SystemInfo$2.run(SystemInfo.java:193)
at com.pi4j.system.SystemInfo$2.run(SystemInfo.java:190)
at java.security.AccessController.doPrivileged(Native Method)
at com.pi4j.system.SystemInfo.isHardFloatAbi(SystemInfo.java:190)
at com.pi4j.util.NativeLibraryLoader.load(NativeLibraryLoader.java:153)
at com.pi4j.wiringpi.Gpio.(Gpio.java:138)
at com.pi4j.io.gpio.RaspiGpioProvider.(RaspiGpioProvider.java:47)
at com.pi4j.io.gpio.GpioFactory.getDefaultProvider(GpioFactory.java:102)
at com.pi4j.io.gpio.impl.GpioControllerImpl.(GpioControllerImpl.java:67)
at com.pi4j.io.gpio.GpioFactory.getInstance(GpioFactory.java:85)
at net.jonathangiles.opensprinkler.OpenSprinklerPiGPIO.(OpenSprinklerPiGPIO.java:85)
at net.jonathangiles.opensprinkler.OpenSprinklerPiGPIO.(OpenSprinklerPiGPIO.java:71)
at net.jonathangiles.opensprinkler.OpenSprinklerFactory.newGpioConnection(OpenSprinklerFacto
ry.java:18)
at org.openhab.binding.opensprinkler.internal.OpenSprinklerBinding.updateBinding(OpenSprinkl
erBinding.java:314)
at org.openhab.binding.opensprinkler.internal.OpenSprinklerBinding.updated(OpenSprinklerBind
ing.java:222)
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:18
3)
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36)
Caused by: java.io.IOException: CreateProcess error=2, Impossibile trovare il file specificato
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
… 25 more
java.io.IOException: Cannot run program “/usr/bin/readelf”: CreateProcess error=2, Impossibile trova
at com.pi4j.system.SystemInfo.getReadElfTag(SystemInfo.java:472)
at com.pi4j.system.SystemInfo.hasReadElfTag(SystemInfo.java:459)
at com.pi4j.system.SystemInfo.access$100(SystemInfo.java:43)
ry.java:18)
erBinding.java:314)
ing.java:222)16:58:40.997 [INFO ] [.service.AbstractActiveService:169 ] - OpenSprinkler Refresh Ser
vice has been started
Caused by: java.io.IOException: CreateProcess error=2, Impossibile trovare il file specificato16:58:
41.259 [DEBUG] [o.o.b.o.i.OpenSprinklerBinding:103 ] - State is not being updated with the OpenSpri
nkler device because access not initialized.
at java.lang.ProcessImpl.<init>(Unknown Source)
... 26 more
pecificato
at com.pi4j.util.NativeLibraryLoader.load(NativeLibraryLoader.java:154)
ry.java:18)
erBinding.java:314)
ing.java:222)
3)
… 25 more
ry.java:18)
erBinding.java:314)
ing.java:222)
3)
… 26 more
16:58:41.452 [ERROR] [.pi4j.util.NativeLibraryLoader:204 ] - Failed to load library [pi4j] using th
e System.load(file) method using embedded resource file: [bundleresource://221.fwk1159114532:2/lib/s
oft-float/libpi4j.so]
16:58:41.459 [ERROR] [.pi4j.util.NativeLibraryLoader:210 ] - ERROR: The native library [pi4j : lib
pi4j.so] could not be found in the JVM library path nor could it be loaded from the embedded JAR res
ource file; you may need to explicitly define the library path ‘-Djava.library.path’ where this nati
ve library can be found.
16:59:41.271 [DEBUG] [o.o.b.o.i.OpenSprinklerBinding:103 ] - State is not being updated with the Op
enSprinkler device because access not initialized.
