Hi All,
I have a small electric vehicle with an OVMS module installed, this allows an optional MQTT connectivity which can then be connected to openhab.
I have created a combination of a widget, plus the .items and .things files to implement all this.
The OVMS module itself is used in many vehicles, so, my below concept should be re-usable.
My requirements, I wanted a small dashboard giving information about my vehicle charge status, allowing to modify some basic parameters (charge speed and max %ge).
To implement this, there are a few steps needed.
You need to have a MQTT server running, I use mosquitto in a docker container.
You need to install the MQTT addon to openhab and connect it to the above MQTT server.
You need to configure the protocol “Server V3 (MQTT)” in OVMS webui.
- This is done under the Config tab, also, set it to autostart.
- Configure your MQTT server, username and password, the topic prefix should be “ovms/”
- Once this is complete, you should start to see messages arriving in your MQTT server. I use MQTT explorer or MQTTX to view the MQTT server activity.
- On Openhab, copy in the .items and .things files.
I do have a “complete” version of these 2 files with all the available parameters from OVMS, but as they are not displayed in the widget it seems pointless to add them all here.
- openhab/conf/things/ovms.things
Thing mqtt:topic:MQTTBroker:Twizy "Twizy" (mqtt:broker:MQTTBroker) {
Channels:
Type number : V_B_Soc "Battery State of Charge" [ stateTopic="ovms/metric/v/b/soc" ]
Type string : V_C_Charging "Currently Charging" [ stateTopic="ovms/metric/v/c/charging" ]
Type number : V_C_Climit "Maximum Charger Output Current" [ stateTopic="ovms/metric/v/c/climit" ]
Type number : V_C_Current "Momentary Charger Output Current" [ stateTopic="ovms/metric/v/c/current" ]
Type number : V_C_Duration_Soc "Estimated Time Remaining for Sufficient SOC" [ stateTopic="ovms/metric/v/c/duration/soc" ]
Type number : V_C_Limit_Soc "Sufficient SOC Limit for Current Charge" [ stateTopic="ovms/metric/v/c/limit/soc" ]
Type number : V_C_Time "Duration of Running Charge" [ stateTopic="ovms/metric/v/c/time" ]
Type number : Cmd_Charge_Limit_Soc "Set Charge SOC Limit" [ commandTopic="ovms/client/openhab/command/1", formatBeforePublish="config set xrt suffsoc %s", retained=false ]
Type string : Cmd_Charge_Limit_Soc_Response "Set Charge SOC Limit - Response" [ stateTopic="ovms/client/openhab/response/1" ]
Type number : Cmd_Charge_Speed "Set Charge Speed Level" [ commandTopic="ovms/client/openhab/command/1", formatBeforePublish="config set xrt chargelevel %s", retained=false ]
Type number : Cmd_Charge_Speed_Response "Set Charge Speed Level - Response" [ commandTopic="ovms/client/openhab/response/1" ]
- openhab/conf/items/ovms.items
Group Twizy "Twizy (OVMS)" <car>
Number Twizy_V_B_Soc "Battery State of Charge" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_B_Soc" }
String Twizy_V_C_Charging "Currently Charging" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Charging" }
Number Twizy_V_C_Climit "Maximum Charger Output Current" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Climit" }
Number Twizy_V_C_Current "Momentary Charger Output Current" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Current" }
Number Twizy_V_C_Duration_Soc "Estimated Time Remaining for Sufficient SOC" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Duration_Soc" }
Number Twizy_V_C_Limit_Soc "Sufficient SOC Limit for Current Charge" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Limit_Soc" }
Number Twizy_V_C_Time "Duration of Running Charge" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:V_C_Time" }
Number Twizy_Cmd_Charge_Limit_Soc "Set Charge SOC Limit" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:Cmd_Charge_Limit_Soc" }
String Twizy_Cmd_Charge_Limit_Soc_Response "Set Charge SOC Limit - Response" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:Cmd_Charge_Limit_Soc_Response" }
Number Twizy_Cmd_Charge_Speed "Set Charge Speed" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:Cmd_Charge_Speed" }
String Twizy_Cmd_Charge_Speed_Response "Set Charge Speed - Response" (Twizy) { channel="mqtt:topic:MQTTBroker:Twizy:Cmd_Charge_Speed_Response" }
- In openhab, create a new widget under developer tab and paste this in:
version: 1
widgets:
Twizy_All_Props:
tags:
- custom
- dark
props:
parameters:
- context: item
default: Twizy_V_B_Soc
description: Battery state of charge
label: Battery SOC
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Charging
description: Charging state
label: Charging state
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Current
description: Actual charging current
label: Charge current
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Climit
description: Maximum charging current
label: Charge current limit
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_Cmd_Charge_Speed
description: Maximum charging index
label: Charge current index limit
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Time
description: Charging duration so far, in seconds
label: Charge duration
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Duration_Soc
description: Time remaining to the target SOC, in seconds
label: Time to SOC target
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_V_C_Limit_Soc
description: Target battery SOC
label: Target SOC
required: true
type: TEXT
groupName: general
- context: item
default: Twizy_Cmd_Charge_Limit_Soc
description: Set Target battery SOC
label: Set Target SOC
required: true
type: TEXT
groupName: general
- default: Twizy
label: Headline
required: false
type: TEXT
groupName: header
- default: twizy.png
label: icon
required: false
type: TEXT
groupName: images
- default: 0
description: Minimum charge current index
label: Minimum current
required: false
type: INTEGER
groupName: controls
- default: 6
description: Maximum charge current index
label: Maximum current
required: false
type: INTEGER
groupName: controls
- default: 1
description: Charge current step
label: Current step
required: false
type: INTEGER
groupName: controls
parameterGroups:
- name: general
label: General settings
description: Items used by the Twizy charging widget
- name: header
label: Header
- name: controls
label: Charge current control
- name: images
label: Images
component: f7-block
class:
- no-padding
- no-margin
style:
position: relative
user-select: none
-moz-user-select: none
-ms-user-select: none
-webkit-user-select: none
slots:
default:
- component: oh-icon
icon: =props.heroIcon
style:
max-width: min(max(70px, 18vw), 110px)
position: absolute
right: 18px
top: 8px
width: 100%
z-index: 20
- component: div
style:
position: absolute
top: 8px
left: 18px
right: calc(18px + min(max(70px, 18vw), 110px) / 2)
height: 60px
z-index: 15
pointer-events: none
slots:
default:
- component: div
innerHTML: <style>@keyframes twzflow{0%{left:0;opacity:0}15%{opacity:1}85%{opacity:1}100%{left:100%;opacity:0}}</style>
- component: div
style:
position: absolute
top: 50%
left: 0
right: 0
height: 3px
margin-top: -1.5px
border-radius: 2px
background: '=["yes","1","ON","true","TRUE"].includes(String(items[props.chargingItem].state)) ? "rgba(255,197,28,0.35)" : "rgba(255,255,255,0.12)"'
- component: div
style:
position: absolute
top: 50%
left: 0
transform: translateY(-50%)
border-radius: 50%
background: rgb(255,197,28)
display: '=["yes","1","ON","true","TRUE"].includes(String(items[props.chargingItem].state)) ? "block" : "none"'
width: =Math.round(6 + Math.min(Math.max(Number.parseFloat(items[props.currentItem].state) || 0, 0), 35) / 35 * 12) + "px"
height: =Math.round(6 + Math.min(Math.max(Number.parseFloat(items[props.currentItem].state) || 0, 0), 35) / 35 * 12) + "px"
box-shadow: ="0 0 " + Math.round(6 + Math.min(Math.max(Number.parseFloat(items[props.currentItem].state) || 0, 0), 35) / 35 * 12) + "px rgba(255,197,28,0.8)"
animation: ="twzflow " + (6 - Math.min(Math.max(Number.parseFloat(items[props.currentItem].state) || 0, 0), 35) / 35 * 4.5).toFixed(2) + "s linear infinite"
- component: f7-card
style:
background: rgb(57,60,76)
border-radius: 20px
margin: 0
min-height: 330px
overflow: hidden
position: relative
slots:
default:
- component: f7-card-content
style:
padding: 18px
position: relative
z-index: 10
slots:
default:
- component: f7-row
style:
align-items: center
min-height: 45px
slots:
default:
- component: f7-col
width: 70%
slots:
default:
- component: Label
style:
color: rgba(255,255,255,0.95)
font-size: 19px
font-weight: 600
letter-spacing: 0.5px
text: =props.headline
- component: Label
style:
color: '=items[props.chargingItem].state == "yes" || items[props.chargingItem].state == "1" || items[props.chargingItem].state == "ON" || items[props.chargingItem].state == "true" || items[props.chargingItem].state == "TRUE" ? "rgb(255,197,28)" : "rgba(255,255,255,0.55)"'
font-size: 13px
font-weight: 500
margin-top: 3px
text: '=items[props.chargingItem].state == "yes" || items[props.chargingItem].state == "1" || items[props.chargingItem].state == "ON" || items[props.chargingItem].state == "true" || items[props.chargingItem].state == "TRUE" ? "CHARGING" : "NOT CHARGING"'
- component: f7-row
style:
justify-content: center
margin-top: 8px
slots:
default:
- component: f7-col
width: 100%
slots:
default:
- component: oh-gauge
type: semicircle
min: 0
max: 100
value: =Number.parseFloat(items[props.socItem].state)
borderWidth: 12
borderColor: rgba(255,255,255,0.12)
borderBgColor: rgba(255,255,255,0.12)
valueText: =Number.parseFloat(items[props.socItem].state).toFixed(0) + "%"
valueTextColor: rgba(255,255,255,0.95)
valueFontSize: 28
style:
margin: 0 auto
- component: Label
style:
color: rgba(255,255,255,0.55)
display: block
font-size: 12px
margin-top: -10px
text-align: center
text: = "TARGET " + Number.parseFloat(items[props.targetSocItem].state).toFixed(0) + "%"
- component: f7-row
style:
align-items: center
margin-top: 5px
slots:
default:
- component: f7-col
width: 45%
slots:
default:
- component: Label
style:
font-size: 12px
text: CHARGE CURRENT
- component: Label
style:
font-size: 22px
font-weight: 600
margin-top: 2px
text: =Number.parseFloat(items[props.currentItem].state).toFixed(1) + " A (" + Number.parseFloat(items[props.currentItem].state*80).toFixed(0) + " w)"
- component: f7-col
width: 55%
style:
text-align: right
slots:
default:
- component: Label
style:
font-size: 12px
text: Charge Speed
- component: Label
style:
color: rgb(255,197,28)
font-size: 22px
font-weight: 600
margin-top: 2px
text: =Number.parseFloat(items[props.currentLimitItem].state).toFixed(1) + " A (" + Number.parseFloat(items[props.currentLimitItem].state*80).toFixed(0) + " w)"
- component: f7-block
class:
- no-padding
- no-margin
style:
background: rgba(255,255,255,0.10)
border-radius: 6px
height: 7px
margin-top: 10px
overflow: hidden
width: 100%
slots:
default:
class:
- no-padding
- no-margin
style:
border-radius: 6px
height: 100%
transition: width 0.3s
width: =Math.min(100, Math.max(0, Number.parseFloat(items[props.currentItem].state) / Number.parseFloat(items[props.currentLimitItem].state) * 100)) + "%"
- component: f7-row
style:
align-items: center
margin-top: 14px
slots:
default:
- component: f7-col
width: 30%
slots:
default:
- component: Label
style:
font-size: 11px
text: SET CHARGE SPEED
- component: f7-col
width: 70%
slots:
default:
- component: oh-stepper
item: =props.currentLimitIndex
min: =Number(props.currentMin)
max: =Number(props.currentMax)
step: =Number(props.currentStep)
fill: true
round: true
raised: true
color: yellow
style:
margin: 0
- component: f7-row
style:
margin-top: 14px
slots:
default:
- component: f7-col
width: 50%
style:
padding-right: 5px
slots:
default:
class:
- no-padding
style:
background: rgba(255,255,255,0.07)
border-radius: 12px
margin: 0
padding: 10px
slots:
default:
- component: Label
style:
color: rgba(255,255,255,0.50)
font-size: 11px
text: CHARGING TIME
- component: Label
style:
font-size: 17px
font-weight: 600
margin-top: 3px
text: =Math.floor(Number.parseFloat(items[props.durationItem].state) / 3600).toString().padStart(2,"0") + ":" + Math.floor((Number.parseFloat(items[props.durationItem].state) % 3600) / 60).toString().padStart(2,"0")
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
style:
font-size: 17px
font-weight: 600
margin-top: 3px
slots:
default:
- component: oh-list-card
config: {}
slots:
default:
- component: oh-input-item
icon: oh:battery
inputmode: numeric
item: =props.targetSocItemSet
outline: true
sendButton: true
showTime: false
min: 60
max: 100
step: 1
title: Max Charge
type: number
useDisplayState: true
style:
- component: f7-col
width: 50%
style:
text-align: right
slots:
default:
- component: Label
style:
color: rgba(255,255,255,0.45)
font-size: 11px
text: STATUS
- component: Label
style:
color: '=items[props.chargingItem].state == "yes" || items[props.chargingItem].state == "1" || items[props.chargingItem].state == "ON" || items[props.chargingItem].state == "true" || items[props.chargingItem].state == "TRUE" ? "rgb(255,197,28)" : "rgba(255,255,255,0.65)"'
font-size: 14px
font-weight: 600
text: '=items[props.chargingItem].state == "yes" || items[props.chargingItem].state == "1" || items[props.chargingItem].state == "ON" || items[props.chargingItem].state == "true" || items[props.chargingItem].state == "TRUE" ? "CHARGING" : "IDLE"'
This widget can then be used in any of your layouts / overview page.
Finally, add the below icon as openhab/conf/icons/classic/twizy.png
Hope someone else finds this useful!
