Here you are:
- openweathermap.items.txt (118.5 KB) → please save as $OPENHAB_CONF/items/openweathermap.items after downloading
- openweathermap.rules.txt (21.1 KB) → please save as $OPENHAB_CONF/rules/openweathermap.rules after downloading
As a bonus you’ll see that I now also generate range items that will display the minimum and maximum values in one go (instead of showing them separately), as with:
String Wx_OWM_Forecast_Temperature_Range_Day0 "Temperature [%s]" <temperature>
I use a rule to compute the state (value) of that Item. The only drawback is that you lose UoM conversion capabilities (e.g. wind speed in my locale is expressed in m/s while most of us are more familiarised with wind speeds in km/h (basically multiplying the values by 3.6 and changing the unit). So my sitemap will properly render min and max wind speeds in km/h but my rule hack will express the values in m/s (with 2-digit precision - something else I can’t easily change in rules).
FWIW I don’t think OpenHAB today allows multiple Number UoM values displayed in one Item while using UoM conversion. It would be great if OpenHAB would allow the following Item definitions:
Number:Speed Wx_OWM_Forecast_Wind_Speed_Range_Day0 "Wind Speed [$1%.0f km/h - $2%.0f km/h]" <wind> (gWeatherForecastDaily)
effectively referring to 2 Number:Speed values rendered as "[%.0f km/h - %.0f km/h]". But that’s a different story. Back to my OWM daily forecast compilation. Now comes the visualisation part.
In your sitemap:
sitemap home label="Our Home" icon="home" {
Frame label="Weather" icon="temperature" {
Text item=Wx_OWM_Current_Observation_Time label="Current weather [%1$tA, %1$tb %1$td, %1$tY]" icon="sun_clouds" {
// Text item=Today label="[%1$tA, %1$tb %1$td, %1$tY]" icon="calendar"
Frame label="Calendar" icon="calendar" {
Text item=Wx_OWM_Current_Observation_Time label="Observation for [%1$tA, %1$tb %1$td]" icon="calendar"
Text item=Wx_OWM_Current_Observation_Time label="Observation at [%1tH:%1$tm]" icon="time"
Default item=Wx_OWM_Current_Station_Name
Default item=Wx_OWM_Current_Station_Id
Frame label="Current weather" icon="sun_clouds" {
Default item=Wx_OWM_Current_Temperature label="Temperature [%.1f %unit%]" valuecolor=[
>=30="red", >=25="orange", >=15="green", 0="silver", <0="purple", <15="blue"
Default item=Wx_OWM_Current_Cloudiness
Default item=Wx_OWM_Current_Humidity icon="humidity" label="Humidity [%d %unit%]"
Default item=Wx_OWM_Current_Pressure
Default item=Wx_OWM_Current_Wind_Speed icon="wind" label="Windspeed [%.0f km/h]"
Default item=Wx_OWM_Current_Wind_Direction
Default item=Wx_OWM_Current_Wind_Direction_Simplified
Default item=Wx_OWM_Current_Rain label="Rain"
Default item=Wx_OWM_Current_Snow label="Snow"
Default item=Wx_OWM_Current_Condition icon="sun_clouds" label="Condition [%s]"
// Default item=Wx_OWM_Current_Condition_Formatted
Default item=Wx_OWM_Current_ConditionIcon label="Icon [%s]"
Default item=Wx_OWM_Current_ConditionId icon="settings" label="Condition ID [%s]"
// Default item=Wx_OWM_Current_Condition_Img_URL label="Current condition (new image)"
// If you persist the group "gWeatherCurrent" and use influxdb persistency, then you can generate the following weekly graphs:
Text label="Graphs [OpenHAB]" icon="chart" {
Text label="Temperature [°C]" icon="temperature"
Chart item=Wx_OWM_Current_Temperature service="influxdb" period=W refresh=500000
Text label="Wind speed [m/s]" icon="wind"
Chart item=Wx_OWM_Current_Wind_Speed service="influxdb" period=W refresh=500000
Text label="Humidity [%]" icon="humidity"
Chart item=Wx_OWM_Current_Humidity service="influxdb" period=W refresh=500000
Text label="Coud cover [%]" icon="sun_clouds"
Chart item=Wx_OWM_Current_Cloudiness service="influxdb" period=W refresh=500000
Text label="Pressure [mBar]" icon="pressure"
Chart item=Wx_OWM_Current_Pressure service="influxdb" period=W refresh=500000
Text label="Rain [mm]" icon="rain"
Chart item=Wx_OWM_Current_Rain service="influxdb" period=W refresh=500000
Text label="Snow [mm]" icon="snow"
Chart item=Wx_OWM_Current_Snow service="influxdb" period=W refresh=500000
Text item=Wx_OWM_Forecast_Time_96h label="Forecast (4 days) [until %1$tA]" icon="sun_clouds" {
Frame item=Wx_OWM_Current_Observation_Time label="Today [%1$tA, %1$tb %1$td]" icon="calendar" visibility=[Wx_OWM_Forecast_Day_Offset==ON] {
Text label="Warning: OWM Forecast Day Offset is TRUE, not enough forecast data for today" icon="error" // visibility=[Wx_OWM_Forecast_Day_Offset==ON]
Frame item=Wx_OWM_Current_Observation_Time label="Today [%1$tA, %1$tb %1$td]" icon="calendar" visibility=[Wx_OWM_Forecast_Day_Offset==OFF] {
// Text label="OWM Forecast Day Offset is FALSE, enough forecast data for today" icon="settings" // visibility=[Wx_OWM_Forecast_Day_Offset==OFF]
Default item=Wx_OWM_Forecast_Temperature_Range_Day0
Default item=Wx_OWM_Forecast_Temperature_Min_Day0 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Max_Day0 valuecolor=[
Default item=Wx_OWM_Forecast_Rain_Day0
Default item=Wx_OWM_Forecast_Snow_Day0
Default item=Wx_OWM_Forecast_Humidity_Range_Day0
Default item=Wx_OWM_Forecast_Humidity_Min_Day0
Default item=Wx_OWM_Forecast_Humidity_Max_Day0
Default item=Wx_OWM_Forecast_Pressure_Range_Day0
Default item=Wx_OWM_Forecast_Pressure_Min_Day0
Default item=Wx_OWM_Forecast_Pressure_Max_Day0
Default item=Wx_OWM_Forecast_Cloudiness_Range_Day0
Default item=Wx_OWM_Forecast_Cloudiness_Min_Day0
Default item=Wx_OWM_Forecast_Cloudiness_Max_Day0
Default item=Wx_OWM_Forecast_Wind_Speed_Range_Day0
Default item=Wx_OWM_Forecast_Wind_Speed_Min_Day0
Default item=Wx_OWM_Forecast_Wind_Speed_Max_Day0
Frame item=Wx_OWM_Forecast_Time_24h label="Tomorrow [%1$tA, %1$tb %1$td]" icon="calendar" {
Default item=Wx_OWM_Forecast_Temperature_Min_Day1 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Max_Day1 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Range_Day1
Default item=Wx_OWM_Forecast_Rain_Day1
Default item=Wx_OWM_Forecast_Snow_Day1
Default item=Wx_OWM_Forecast_Humidity_Range_Day1
Default item=Wx_OWM_Forecast_Humidity_Min_Day1
Default item=Wx_OWM_Forecast_Humidity_Max_Day1
Default item=Wx_OWM_Forecast_Pressure_Range_Day1
Default item=Wx_OWM_Forecast_Pressure_Min_Day1
Default item=Wx_OWM_Forecast_Pressure_Max_Day1
Default item=Wx_OWM_Forecast_Cloudiness_Range_Day1
Default item=Wx_OWM_Forecast_Cloudiness_Min_Day1
Default item=Wx_OWM_Forecast_Cloudiness_Max_Day1
Default item=Wx_OWM_Forecast_Wind_Speed_Range_Day1
Default item=Wx_OWM_Forecast_Wind_Speed_Min_Day1
Default item=Wx_OWM_Forecast_Wind_Speed_Max_Day1
Frame item=Wx_OWM_Forecast_Time_48h label="In 2 days [%1$tA, %1$tb %1$td]" icon="calendar" {
Default item=Wx_OWM_Forecast_Temperature_Min_Day2 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Max_Day2 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Range_Day2
Default item=Wx_OWM_Forecast_Rain_Day2
Default item=Wx_OWM_Forecast_Snow_Day2
Default item=Wx_OWM_Forecast_Humidity_Range_Day2
Default item=Wx_OWM_Forecast_Humidity_Min_Day2
Default item=Wx_OWM_Forecast_Humidity_Max_Day2
Default item=Wx_OWM_Forecast_Pressure_Range_Day2
Default item=Wx_OWM_Forecast_Pressure_Min_Day2
Default item=Wx_OWM_Forecast_Pressure_Max_Day2
Default item=Wx_OWM_Forecast_Cloudiness_Range_Day2
Default item=Wx_OWM_Forecast_Cloudiness_Min_Day2
Default item=Wx_OWM_Forecast_Cloudiness_Max_Day2
Default item=Wx_OWM_Forecast_Wind_Speed_Range_Day2
Default item=Wx_OWM_Forecast_Wind_Speed_Min_Day2
Default item=Wx_OWM_Forecast_Wind_Speed_Max_Day2
Frame item=Wx_OWM_Forecast_Time_72h label="In 3 days [%1$tA, %1$tb %1$td]" icon="calendar" {
Default item=Wx_OWM_Forecast_Temperature_Range_Day3
Default item=Wx_OWM_Forecast_Temperature_Min_Day3 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Max_Day3 valuecolor=[
Default item=Wx_OWM_Forecast_Rain_Day3
Default item=Wx_OWM_Forecast_Snow_Day3
Default item=Wx_OWM_Forecast_Humidity_Range_Day3
Default item=Wx_OWM_Forecast_Humidity_Min_Day3
Default item=Wx_OWM_Forecast_Humidity_Max_Day3
Default item=Wx_OWM_Forecast_Pressure_Range_Day3
Default item=Wx_OWM_Forecast_Pressure_Min_Day3
Default item=Wx_OWM_Forecast_Pressure_Max_Day3
Default item=Wx_OWM_Forecast_Cloudiness_Range_Day3
Default item=Wx_OWM_Forecast_Cloudiness_Min_Day3
Default item=Wx_OWM_Forecast_Cloudiness_Max_Day3
Default item=Wx_OWM_Forecast_Wind_Speed_Range_Day3
Default item=Wx_OWM_Forecast_Wind_Speed_Min_Day3
Default item=Wx_OWM_Forecast_Wind_Speed_Max_Day3
Frame item=Wx_OWM_Forecast_Time_96h label="In 4 days [%1$tA, %1$tb %1$td]" icon="calendar" {
Default item=Wx_OWM_Forecast_Temperature_Range_Day4
Default item=Wx_OWM_Forecast_Temperature_Min_Day4 valuecolor=[
Default item=Wx_OWM_Forecast_Temperature_Max_Day4 valuecolor=[
Default item=Wx_OWM_Forecast_Rain_Day4
Default item=Wx_OWM_Forecast_Snow_Day4
Default item=Wx_OWM_Forecast_Humidity_Range_Day4
Default item=Wx_OWM_Forecast_Humidity_Max_Day4
Default item=Wx_OWM_Forecast_Humidity_Min_Day4
Default item=Wx_OWM_Forecast_Pressure_Range_Day4
Default item=Wx_OWM_Forecast_Pressure_Min_Day4
Default item=Wx_OWM_Forecast_Pressure_Max_Day4
Default item=Wx_OWM_Forecast_Cloudiness_Range_Day4
Default item=Wx_OWM_Forecast_Cloudiness_Min_Day4
Default item=Wx_OWM_Forecast_Cloudiness_Max_Day4
Default item=Wx_OWM_Forecast_Wind_Speed_Range_Day4
Default item=Wx_OWM_Forecast_Wind_Speed_Min_Day4
Default item=Wx_OWM_Forecast_Wind_Speed_Max_Day4
// Add your other home automation stuff
I agree. And it would also be much more efficient in terms of resources.
