I updated to 3.3 M3, Previous issues now gone but see some new issues?
Non of the channels are writable. I cannot change the mode setting via sitemap button. The item states do now reflect the 3550 mode. But if I change from manual to weekly program the manual set temperature changes from the setpoint previous manual 20 to 11.5C. No idea where the 11.5 value comes from?
Initial state after creating items:
- failureDiscovered is OFF
- atLeastOneProbeOff has state ON but does not update
- atLeastOneProbeProtection has state ON but does not update
- atLeastOneProbeManual remains null unitl manual set for a zone on the 3550 unit
I can change the states using the sitemap switch eg set all to OFF Then when setting Protection on one thermostat >> Protection changes to ON, setting to OFF >>> protection stays ON and âOFFâ switch became ON and both stay there until I change them on the site map. Likewise manual mode setting on one probe via the 355o cause the manual mode switch to become ON but it does not return to OFF. So, for me its the same behaviour as Stefan saw.
Changing local settings on thermostat shows nothing in the log (min logging) Using site map switches causes these warnings in the log:
2022-04-22 10:48:27.492 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeOff
2022-04-22 10:48:28.656 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeProtection
2022-04-22 10:48:44.040 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeOff
2022-04-22 10:48:45.004 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeOff
2022-04-22 10:48:45.863 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeManual
2022-04-22 10:48:46.516 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeManual
2022-04-22 10:48:47.647 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeProtection
2022-04-22 10:48:48.370 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID atLeastOneProbeProtection
2022-04-22 10:48:49.205 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID failureDiscovered
2022-04-22 10:48:50.016 [WARN ] [er.OpenWebNetThermoregulationHandler] - handleChannelCommand() Unsupported ChannelUID failureDiscovered
.items
Group gCentralUnit "Central Unit"
String CU3550_mode "Mode" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:mode"}
String CU3550_function "Function" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:function"}
Number:Temperature CU3550_ManualSetpoint "Manual setpoint temperature" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:setpointTemperature"}
String CU3550_remote "Remote Control" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:remoteControl"}
String CU3550_battery "Battery Status" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:batteryStatus"}
Number CU3550_wpn "Weekly Program" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:weeklyProgram"}
Number CU3550_spn "Scenario Program" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:scenarioProgram"}
Switch atLeastOneProbeOff "A probe is OFF" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:atLeastOneProbeOff"}
Switch atLeastOneProbeProtection "A probe is in frost protection" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:atLeastOneProbeProtection"}
Switch atLeastOneProbeManual "A probe is in manual mode" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:atLeastOneProbeManual"}
Switch failureDiscovered "Failure" <temperature> (gCentralUnit) {channel="openwebnet:bus_thermo_cu:gateway:3550:failureDiscovered"}
.thing
Thing bus_thermo_cu 3550 "Heating control" [ where="0" ]
Thing bus_thermo_zone 1 "West bathroom heating zone" [ where="1", standAlone="false" ]
Thing bus_thermo_zone 2 "West bedroom heating zone" [ where="2", standAlone="false" ]
Thing bus_thermo_zone 3 "East bedroom heating zone" [ where="3", standAlone="false" ]
Thing bus_thermo_zone 4 "East bathroom heating zone" [ where="4", standAlone="false" ]
Thing bus_thermo_zone 5 "Lounge heating zone" [ where="5", standAlone="false" ]
Thing bus_thermo_zone office "Office heating zone" [ where="6", standAlone="false" ]
Thing bus_thermo_zone 7 "Dining room heating zone" [ where="7", standAlone="false" ]
Thing bus_thermo_zone 8 "Guest bathroom heating zone" [ where="8", standAlone="false" ]
Thing bus_thermo_zone 9 "Home cinema heating zone" [ where="9", standAlone="false" ]
Thing bus_thermo_zone 10 "South bedroom heating zone" [ where="10", standAlone="false" ]
Thing bus_thermo_zone 11 "Gallery heating zone" [ where="11", standAlone="false" ]
Thing bus_thermo_zone 12 "Utility room heating zone" [ where="12", standAlone="false" ]
.sitemap ⊠if you want the buttons to have a nice name
Switch item=CU3550_wpn label="Weekly pgm []" mappings=[1="Work", 2="Home", 3="Spring"]
P.s. What does the 'advancedâcolumn signify in the documentation table for thermo?
