Platform information:
Hardware: Raspberry pi 3B+
OS: Raspbian 10
Java Runtime Environment: openjdk 11.0.6
openHAB version: 2.5.9 Release
OpenWebNet (BTicino/Legrand) Binding installed
Issue of the topic:
Hi all,
I’ve set up my MH200N to handle all the lightning and it works fine.
Now I would like to add my thermostats but I cannot find a working example.
The documentation does not clearly say it supports WHO=4… though I found some examples on this forums, but no luck for me. And by the way there should really be some way to indicate that a topic is outdated. When I’m stuck and look on this forum I always find outdated stuff that point me in the wrong direction
Here is my configuration :
BTicino.things :
Bridge openwebnet:bus_gateway:mybridge "MyHOMEServer1" [ host="192.168.0.xxx", passwd="xxx", port=20000, discoveryByActivation=true ] { bus_on_off_switch SalleManger_Switch "Salle à manger" [ where="15" ] bus_on_off_switch Cuisine_Switch "Cuisine" [ where="16" ] bus_on_off_switch LampeSalon_Switch "Lampe du salon" [ where="17" ] bus_on_off_switch EvierCuisine_Switch "Evier cuisine" [ where="18" ] bus_on_off_switch Sonnette_Switch "Sonnette" [ where="47" ] bus_thermostat LR_thermostat "Thermostat du Living" [ where="1"] }
BTicino.items :
Switch SalleManger_Switch “Salle à manger” { ga=“Switch”, channel=“openwebnet:bus_on_off_switch:mybridge:SalleManger_Switch:switch” }
Switch Cuisine_Switch “Cuisine” { ga=“Switch”, channel=“openwebnet:bus_on_off_switch:mybridge:Cuisine_Switch:switch” }
Switch LampeSalon_Switch “Salon” { ga=“Switch”, channel=“openwebnet:bus_on_off_switch:mybridge:LampeSalon_Switch:switch” }
Switch EvierCuisine_Switch “Evier de la Cuisine” { ga=“Switch”, channel=“openwebnet:bus_on_off_switch:mybridge:EvierCuisine_Switch:switch” }
Switch Sonnette_Switch “Sonnette” { ga=“Switch”, channel=“openwebnet:bus_on_off_switch:mybridge:Sonnette_Switch:switch” }Group gLR_thermostat “Living Room Thermostat” [ “Thermostat” ]
Number:Temperature iLR_temp “Temperature [%.1f °C]” (gLR_Thermostat) [ “CurrentTemperature” ] { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:temperature” }
String iLR_offset “Offset” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:localMode” }
Switch iLR_heating “Heating is” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:heating” }
Switch iLR_cooling “Cooling is” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:cooling” }
Number:Temperature iLR_targetTemp “Target [%.1f °C]” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:targetTemperature” }
String iLR_activeMode “Active Mode” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:activeMode” }
String iLR_heatCool “HeatingCoolingMode” (gLR_Thermostat) [ “homekit:HeatingCoolingMode” ] { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:heatingCoolingMode” }
Number:Temperature iLR_setpointTemp “Setpoint Temperature [%.1f °C]” (gLR_Thermostat) [ “TargetTemperature” ] { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:setpointTemperature” }
String iLR_setMode “Set Mode” (gLR_Thermostat) { channel=“openwebnet:bus_thermostat:mybridge:LR_thermostat:setMode”}
I only declared one thermostat for testing purpose.
The lights are working all right, I can even control them with my Google Assistant, but the thermostat just does not work. It’s showing in Google Home but not working. It’s not showing in the paper ui control tab that I use for debugging purposes.
The logs (set to debug) does not show anything about the thermostats. :-/
Any help is appreciated
Michel
PS: the </> button is just making a mess, I cannot format my posts… not the first time I’m trying… using Chrome here. So I used " instead.
