Hi, I’m new to Openhab.
After about a month, everything works and the system is very clear.
But now I stopped and I can’t go on the Bticino thermostat with 3550 central unit.
Everything works well on openhab
on Google assistant I can’t manage the set point despite having configured the tags correctly as shown in the tutorials. Are there any problems with the latest update of the Google Home app?
I can only read the temperature and nothing else.
Same here: after May update of Google Home App, my thermostats are “not responding”. I relinked the openhab account, checked all the tags in items file, but they does not work no more. Everything is still working well with paperUi or BasicUi. Only the Google Home app does not see thermostats. Lights and google devices are still ok.
Scusami ma non ho capito come usare code fences
di seguito ti invio il file scritto:
Group gCucina_Thermostat “Cucina Thermostat” [ “Thermostat”, “Celsius” ]
Number Cucina_Temp “Temperature [%.1f °C]” (gCucina_Thermostat) [ “CurrentTemperature” ]
String Cucina_HeatCool “HeatingCoolingMode” (gCucina_Thermostat) [ “homekit:HeatingCoolingMode” ]
Number Cucina_SetpointTemp “Setpoint Temperature [%.1f °C]” (gCucina_Thermostat) [ “TargetTemperature” ]
Dove è scritto Termostato Celsius chiaramente è un errore di distrazione.
Nel file è scritto correttamente Thermostat Celsius.
Press button
your code goes here
Paste your code instead of the text your code goes here
If you do not use this procedure, you will lose useful information
Ok grazie
this forum is in English, if you continue to use other languages, posts will be blocked
Group gCucina_Thermostat "Cucina Thermostat" [ "Thermostat", "Celsius" ]
Number Cucina_Temp "Temperature [%.1f °C]" <temperature> (gCucina_Thermostat) [ "CurrentTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:temperature" }
String Cucina_Offset "Offset" (gCucina_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:localMode" }
Switch Cucina_Heating "Heating is" (gCucina_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:heating" }
Number Cucina_TargetTemp "Target [%.1f °C]" (gCucina_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:targetTemperature" }
String Cucina_ActiveMode "Active Mode" (gCucina_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:activeMode" }
String Cucina_HeatCool "HeatingCoolingMode" (gCucina_Thermostat) [ "homekit:HeatingCoolingMode" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:heatingCoolingMode" }
Number Cucina_SetpointTemp "Setpoint Temperature [%.1f °C]" <temperature> (gCucina_Thermostat) [ "TargetTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:setpointTemperature" }
String Cucina_SetMode "Set Mode" (gCucina_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:1:setMode"}
Group gSalone_Thermostat "Salone Thermostat" [ "Thermostat", "Celsius" ]
Number Salone_Temp "Temperature [%.1f °C]" <temperature> (gSalone_Thermostat) [ "CurrentTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:temperature" }
String Salone_Offset "Offset" (gSalone_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:localMode" }
Switch Salone_Heating "Heating is" (gSalone_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:heating" }
Number Salone_TargetTemp "Target [%.1f °C]" (gSalone_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:targetTemperature" }
String Salone_ActiveMode "Active Mode" (gSalone_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:activeMode" }
String Salone_HeatCool "HeatingCoolingMode" (gSalone_Thermostat) [ "homekit:HeatingCoolingMode" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:heatingCoolingMode" }
Number Salone_SetpointTemp "Setpoint Temperature [%.1f °C]" <temperature> (gSalone_Thermostat) [ "TargetTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:setpointTemperature" }
String Salone_SetMode "Set Mode" (gSalone_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:2:setMode"}
Group gBagno_Thermostat "Bagno Thermostat" [ "Thermostat", "Celsius" ]
Number Bagno_temp "Temperature [%.1f °C]" <temperature> (gBagno_Thermostat) [ "CurrentTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:temperature" }
String Bagno_Offset "Offset" (gBagno_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:localMode" }
Switch Bagno_Heating "Heating is" (gBagno_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:heating" }
Number Bagno_TargetTemp "Target [%.1f °C]" (gBagno_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:targetTemperature" }
String Bagno_ActiveMode "Active Mode" (gBagno_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:activeMode" }
String Bagno_HeatCool "HeatingCoolingMode" (gBagno_Thermostat) [ "homekit:HeatingCoolingMode" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:heatingCoolingMode" }
Number Bagno_SetpointTemp "Setpoint Temperature [%.1f °C]" <temperature> (gBagno_Thermostat) [ "TargetTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:setpointTemperature" }
String Bagno_SetMode "Set Mode" (gBagno_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:3:setMode"}
Group gCameretta_Thermostat "Cameretta Thermostat" [ "Thermostat", "Celsius" ]
Number Cameretta_Temp "Temperature [%.1f °C]" <temperature> (gCameretta_Thermostat) [ "CurrentTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:temperature" }
String Cameretta_Offset "Offset" (gCameretta_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:localMode" }
Switch Cameretta_Heating "Heating is" (gCameretta_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:heating" }
Number Cameretta_TargetTemp "Target [%.1f °C]" (gCameretta_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:targetTemperature" }
String Cameretta_ActiveMode "Active Mode" (gCameretta_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:activeMode" }
String Cameretta_HeatCool "HeatingCoolingMode" (gCameretta_Thermostat) [ "homekit:HeatingCoolingMode" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:heatingCoolingMode" }
Number Cameretta_SetpointTemp "Setpoint Temperature [%.1f °C]" <temperature> (gCameretta_Thermostat) [ "TargetTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:setpointTemperature" }
String Cameretta_SetMode "Set Mode" (gCameretta_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:4:setMode"}
Group gLetto_Thermostat "Letto Thermostat" [ "Thermostat", "Celsius" ]
Number Letto_Temp "Temperature [%.1f °C]" <temperature> (gLetto_Thermostat) [ "CurrentTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:temperature" }
String Letto_Offset "Offset" (gLetto_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:localMode" }
Switch Letto_Heating "Heating is" (gLetto_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:heating" }
Number Letto_TargetTemp "Target [%.1f °C]" (gLetto_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:targetTemperature" }
String Letto_ActiveMode "Active Mode" (gLetto_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:activeMode" }
String Letto_HeatCool "HeatingCoolingMode" (gLetto_Thermostat) [ "homekit:HeatingCoolingMode" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:heatingCoolingMode" }
Number Letto_SetpointTemp "Setpoint Temperature [%.1f °C]" <temperature> (gLetto_Thermostat) [ "TargetTemperature" ] { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:setpointTemperature" }
String Letto_SetMode "Set Mode" (gLetto_Thermostat) { channel="openwebnet:bus_thermostat:F454_0003508f0e04:5:setMode"}
I can’t understand why it doesn’t work, before it worked.
Hi, Massimo.Another thing I noticed and that on the android openhab app if I set Classic Ui I see all the features of the items file (so temperature, target heating cooling mode active mode, etcccc)
if instead I set Basic ui on the sitemap (after I created the sitemap file) I only see temperature and offset.
sitemap casa label="Casa" {
Frame {
Group item=Bedroom
Group item=Corridor
Group item=Entryway
Group item=LivingRoom
Group item=MasterBedroom
Group item=Kitchen
Group item=Toilet
Frame {
Text label="Termostati" icon="heating" {
Default item=gLR_Thermostat label="Salone Termostato"
Text label="Elettricità" icon="poweroutlet" {
Default item=Corridor_Power label="Disimpegno"
Default item=LivingRoom_Power label="Salone"
Default item=Kitchen_Power label="Cucina"
I would like to manage the temperature set point via the openhab app
Hello guys,
I joined this post because I have the same problem: my thermostat integration with Google home worked fine until few days ago, on Google home app the thermostat is not responding but everything is fine on OpenHab app.
Other items like switch are still working fine in both apps.
Thank you
Bernardo
It still doesn’t work for me. Are there any news?
there is a bug in the Google Assistant integration in the cloud (it’s not related to OpenWebNet : it’s the integration with Google Assistant that has problems).
See here to track:
Ok thanks solved
Roberto, Would you be so kind to share with others how did you solve the problem?
The problem is in the Google Assistant integration and not yet solved, so if you have found a way to solve it using some other temporary workaround would be very useful for other users as well.
Hi, Massimo, more than solved, I kept to your indications on the tag to change. https://github.com/openhab/openhab-google-assistant/issues/92.
In my case I solved it because I needed to manage the set point and visualize the temperature. I don’t need the Off mode.
Hi Massimo, in your current developing of new binding for OH3 is thermi bticino still supported?
thanks (in oh2.5 I never saw its…)
