Dear Openhabians,
I don’t know if I’m the only one with that problem, but I use my Android tablet to edit some of my widget code. The Syntax checking in the Main UI however is making this a nightmare.
You can clearly see the checks lag behind, depending on how long the code is, resulting in a jumping input cursor while you type.
My Tablet should be able to Handle some CPU Load, but maybe the system or chrome is limiting how much can be used.
Long story short: Is there a possibility to deactivate these bells and whistles on the Main UI widget/code editor? I’d rather have it check my code once when I save it…
Thank you so much!
