I want, that my blinds move up in the morning, but not, when it is raining. If the tempreture outside is below 1 °C and it is raining - in this case i think it is snowing - the blinds should go up.
I´m using the following rule:
rule "Morgens hoch"
Channel
'astro:sun:30ae654b:civilDawn#event' triggered START
Esszimmer_Raffstore_4_Level2.sendCommand(100)
Wohnzimmer_Ost_Raffstore_4_Level2.sendCommand(100)
Kueche_Raffstore_4_Level2.sendCommand(100)
timerRaffstoreAuf=createTimer(now.plusSeconds(15))[|
Wohnzimmer_Raffstore_Terasse_Fenster_1_Level.sendCommand(UP)
Wohnzimmer_Raffstore_Terrasse_TRe_1_Level.sendCommand(UP)]
if ((Garten_Regensensor_1_State.state == 0) || (Aussenmodul_Temperature.state < 1)) {
KChe_Raffstore_4_Level.sendCommand(100) // Raffstore ist ganz geöffnet
Wohnzimmer_Ost_Raffstore_4_Level.sendCommand(100)
Esszimmer_Raffstore_4_Level.sendCommand(100)}
Problem is, that rule works fine, when the tempreture is below 1 °, but not, when the temperature is over 1°. Somewhere i read, that “||” means OR - is that correct? When not, how can i realize my rule??
From that I would say you want the blinds to go up always if it is below 1°C or when the temperature is higher and it is not raining.
Try to make an if out of that.
if (Aussenmodul_Temperature.state < 1) {
if (Aussenmodul_Temperature.state > 1) {
if (Garten_Regensensor_1_State.state == 0) [
Esszimmer_Raffstore_4_Level.sendCommand(100)]}
