Trying to install OpenHab2 on a Orange Pi running Raspbian. I’ve managed to install the package via apt-get but when I try to start it i get this:
root@RR-ORANGE:~# sudo /etc/init.d/openhab2 start
[ ok ] Starting openHAB2 server: openhab2.
root@RR-ORANGE:~# sudo /etc/init.d/openhab2 status
/var/lib/openhab2/tmp/port shutdown port file doesn't exist. The container is not running.
I’m suspecting some sort of permissions problem since I can start it running the start script. I’m just not sure how to start debugging this.
So you might put latest Armbian on your OPi. Those folks did a great job fixing all the Orange Pi issues. Use the 4X tree. I setup their build environment in a virtual, and compile their full builds of the OS then flash image on my SD, then use their armbian-config to push on eMMC. Now have very stable solution. Hope that helps. my OPi is a 2 plus. The also have large number of other pi like builds for those looking for stable OS to work with.
Thanks for your input. I did look at Armbian and seriously considered using it but I don’t have the time available to commit to that. My SD card died on my RPi so OpenHab was no more. I had backups of the OpenHab files so I just wanted to drop them on a new build quickly. I threw if all back together on an RPi 3 just for expediency. I may take a look at that option later though since you appear to have had a good experience with it.
