IO972
(melissa)
May 6, 2020, 8:18pm
#1
Platform information:
Hardware: RasPi3b+/32GB
Os : Linux 4.19.66-v7+
openHAB version: openHabain 2.5.4-1
I start with the demo, because it for a test
I would like to order my openhab with wav files or txt files.
I install Pico Text-to from the addons in Paper UI and by using this method https://www.openhab.org/addons/voice/picotts/#overview
But now I would like know where I should put my order files.
Anyone can help me please?
H102
(CM6.5 H102)
May 7, 2020, 12:14pm
#2
Welcome to the Community!
I would use standard install, even if just for a test as you may be limited with demo.
I do not use Pico but this may help.
IO972
(melissa)
June 4, 2020, 7:25am
#3
Hi H102, thank you for your answer, she helped me in my research. I finally found a solution by using txt file.
Rule “nom de la rule”
Time cron “* 0/5 * * * ?” (For this example I create a clock of 5 minutes)
Then
var String chemin = executeCommandLine(“cat /home/openhabian/MonFichier.txt”,1000)
logInfo(“nlu”,"contenue du fichier txt " +chemin)
if (chemin.contains(“allume la lumière”)){
hue1.send(ON)
jcurado
(João Curado)
June 4, 2020, 7:56am
#4
Hello
I use voice control from Android App. Maybe you can use a similar approach:
rule "controlo por voz"
Item VoiceCommand received command
var String command = VoiceCommand.state.toString.toLowerCase
sendNotification("xxxxxxx@gmail.com", "Recebi comando " + command)
if (Mensagens.state==ON)
say(command , "voicerss:ptPT", "sonos:PLAY1:sala")
if (MenTVSala.state==ON)
LG_TV0_Toast.sendCommand(command)
if (command.contains("acende")||command.contains("acender")||command.contains("liga")||command.contains("ligar"))
if (command.contains("biblioteca"))
LampadaTetoBiblio.sendCommand(ON)
else if (command.contains("quarto"))
LampadaQPrincipal.sendCommand(ON)
else if (command.contains("laura"))
LampadaLaura.sendCommand(ON)
else if (command.contains("sala"))
LampadaTetoSalaTV.sendCommand(ON)
else if (command.contains("escada"))
LampadaEscada.sendCommand(ON)
else if (command.contains("cozinha"))
LampadaCozinha.sendCommand(ON)
else if (command.contains("entrada"))
LampadaHallPatio.sendCommand(ON)
else if (command.contains("computador"))
ValorLampBiblio.sendCommand("13")
else if (command.contains("apaga")||command.contains("apagar")||command.contains("desliga")||command.contains("desligar"))
if (command.contains("biblioteca")||command.contains("computador"))
LampadaTetoBiblio.sendCommand(OFF)
LampadaQPrincipal.sendCommand(OFF)
LampadaLaura.sendCommand(OFF)
LampadaTetoSalaTV.sendCommand(OFF)
LampadaEscada.sendCommand(OFF)
LampadaCozinha.sendCommand(OFF)
LampadaHallPatio.sendCommand(OFF)
ValorLampBiblio.sendCommand(OFF)
else if (command.contains("tudo"))
Lampadas.sendCommand(OFF)
else if (command.contains("abre")||command.contains("abrir"))
if (command.contains("quintal"))
PortaoPatioAbre.sendCommand(ON)
AbreTudo.sendCommand(ON)
ValorEstBiblio1.sendCommand("100")
ValorEstBiblio2.sendCommand("100")
ValorEstBiblio3.sendCommand("100")
ValorEstQPrincipal.sendCommand("100")
else if (command.contains("fecha")||command.contains("fechar"))
PortaoPatioFecha.sendCommand(ON)
FechaTudo.sendCommand(ON)
ValorEstBiblio1.sendCommand("0")
ValorEstBiblio2.sendCommand("0")
ValorEstBiblio3.sendCommand("0")
ValorEstQPrincipal.sendCommand("0")
