Issue of the topic:
I noticed that the following errors are very frequent in my openhab.log
Note that I don’t have a sitemap called ‘gZwave’. (I have a group called gZwave)
2019-08-20 12:12:28.665 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/sitemaps/default/gZwave
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_19125,19126,2870548) has been shut down
sure. I tried earlier but the site didn’t accept the .sitemap extension.
I changed to .txt
(why the forum does not accept the common openhab file extensions?)
I can’t say much about the posted error, however in your complete log it seems as if each and every web request does not return anything. Does this instance have a connection to the internet? It seems not.
Since your sitemap does show only groups and you posted only the group setup and not a single item definition we can’t say much about that.
I changed to .txt
Because looking at file attachments is a huge pain, particularly if you are answering from a disadvantaged device like a phone.
You can just paste the contents in and How to use code fences, just like you did with the log statements.
sitemap default label="Varazze's House"
Frame label="All" {
Group item=gAll
Frame label="Cloud" {
Group item=gCloud
// GRUPPI
Group gAll "GruppoRoot" <sofa>
Group gWeather "GruppoMeteo" <sofa> (gAll)
Group gSalotto "GruppoSalotto" <sofa> (gAll)
Group gNetwork "Gruppo rete" (gAll)
Group gDateTime "GruppoDatetime" <calendar> (gAll)
Group gZwave "GruppoZwave" <sofa> (gAll)
Group gzRGBW "GruppoRGBW" <sofa> (gZwave)
Group gMilight "GruppoMilight" <sofa> (gSalotto)
Group gTestroom "GruppoTest" <calendar> (gAll)
Group gX10 "GruppoX10" <calendar> (gSalotto)
Group gXBMC "Gruppo XBMC" (gSalotto)
Group gXBMCtest "Gruppo XBMCtest" (gSalotto)
Group gSB "Gruppo SqueezeBox" (gSalotto)
Group gInitNull "GruppoInitNull"
Group gHT "Home theatre" (gSalotto)
Group gXiaomi "Xiaomi" (gAll)
Group gESP "ESP" <sofa> (gAll)
Group gUPS "UPS" <sofa> (gAll)
Group gPool "POOL" (gAll)
Group gHDTemperature "HD Temp" (gAll)
Group gRoomTemperature "Room Temp" (gAll)
Group gSysInfo "System Info" (gAll)
Group gPersist "Restore On Startup" (gAll)
Group gPersistHourly "Store hourly" (gAll)
Group gPersistChange "Store changes" (gAll)
Group gPersistUpdate "Store updates" (gAll)
Group gCloud "allow MyOpenHab.org access"
Group gEnergy "Delios" (gAll)
Group gTado (gAll)
Group gESPT1 (gESP)
Group gESPT2 (gESP)
Group gESPT3 (gESP)
Group gESPT4 (gESP)
Group gESPT5 (gESP)
Group gESPT6 (gESP)
Group gESPT7 (gESP)
Group gESPT8 (gESP)
Group gESPT9 (gESP)
Group gESPT10 (gESP)
Group gESPT11 (gESP)
Group:Contact:OR(OPEN,CLOSED) gESPRelay (gESP)
Group:Contact:OR(OPEN,CLOSED) gESPPushButtons (gESP)
Group:String gESPAlarms (gESP)
Group:Switch:OR(ON,OFF) gZwaveSwitches (gZwave)
Group:Number:Temperature gTadoTemp (gTado)
Group:Number gTadoHum (gTado)
Group:Number gTadoHP (gTado)
Group:String gTadoHVAC (gTado)
Group:Number:Temperature gTadoSetPoint (gTado)
Group:DateTime gTadoExpiry (gTado)
Group:Number gTadoTimer (gTado)
Group:String gTadoMode (gTado)
Group gTadoZ1 (gTado)
Group gTadoZ2 "Zona Giorno" (gTado)
Group gTadoZ3 "Blue Room" (gTado)
Group gTadoZ4 (gTado)
Group gTadoZ5 "Green Room" (gTado)
Group gTadoZ6 (gTado)
Group gTadoZ7 "Bagno Grigio" (gTado)
Group gTadoZ8 "Yellow Room" (gTado)
Group gTadoZ9 "Bagno Verde" (gTado)
Group gTadoZ10 "Yellow Room" (gTado)
What URL are you using to access the sitemap? Are you using one of the phone apps?
