I’m running the latest docker snapshot 2.4.0-snapshot-amd64-debian
(Build #1392), and trying to use the REST API from a web application.
I’m getting a Cross-Origin Request Blocked
error, and so have enabled the option org.eclipse.smarthome.cors:enable=true
in my runtime.cfg
as suggested. After doing this and restarting, I can now see this in the logs:
2018-10-21 09:34:37.561 [INFO ] [e.io.rest.internal.filter.CorsFilter] - enabled CORS for REST API.
So I think I have set it correctly, however I’m still having the issue in my web app.
Looking at the output in curl
, I see there is no Access-Control-Allow-Origin
header (as I would expect, but maybe wrong here), for example:
$ curl http://openhab.sf:8080/rest/items/myswitch -v
* Trying 10.7.0.10...
* TCP_NODELAY set
* Connected to openhab.sf (10.7.0.10) port 8080 (#0)
> GET /rest/items/myswitch HTTP/1.1
> Host: openhab.sf:8080
> User-Agent: curl/7.54.0
> Accept: */*
< HTTP/1.1 200 OK
< Content-Type: application/json
< Content-Length: 216
< Server: Jetty(9.4.11.v20180605)
* Connection #0 to host openhab.sf left intact
{"link":"http://openhab.sf:8080/rest/items/myswitch","state":"ON","editable":false,"type":"Switch","name":"myswitch","label":"Pool Pump","category":"switch","tags":[],"groupNames":["sonoff","gDBPersist"]}
So I tried looking in the source for the implementation (at https://github.com/openhab/openhab2-addons and https://github.com/openhab/openhab-core) but couldn’t anything even referencing cors
, so clearly looking in the wrong spot (or GitHub search is not working, which is possible).
So am I missing something obvious, or is there a bigger issue at play here?
Thanks in advance!
