Running Openhabian stable on Raspberry PI 3
I uninstalled the standard Anal binding as this one still has the Anel firmware 6.1 issue.
(https://github.com/openhab/openhab1-addons/pull/5264)
and installed : org.openhab.binding.anel-1.11.0-SNAPSHOT.jar
openhab> bundle:list
205 | Active | 80 | 1.11.0.201708221612 | openHAB Anel Binding
openhab>
vi /srv/openhab2-conf/services/anel.cfg
IP or network address (optional but recommended, defaults to ‘net-control’)
#.host=anel1
anel1.host=anel1
UDP receive port (optional, defaults to 77)
anel1.udpReceivePort=77
UDP send port (optional, defaults to 75)
anel1.udpSendPort=75
User name (optional, defaults to ‘user7’)
#.user=user1
anel1.user=admin
/etc/hosts has :
192.168.5.240 anel1
But getting ton’s of errors like this :
[ERROR] [ng.anel.internal.AnelConnectorThread] - Error occured when sending UDP data to Anel device: ‘wer da?’
java.lang.Exception: Could not resolve host: net-control
=> looks like the anel.cfg file isn’t used and that the default hostname “net-control” is used …
Did add host net-control in /etc/hosts pointing to the same ip and this works => so think the new binding is not using anel.cfg and using default config settings and using net-control ?
[ItemStateChangedEvent ] - anelTemperature changed from 22.9 to 23.1
[ItemStateChangedEvent ] - f8 changed from ON to OFF
But I need to be able to use the config file anel.cfg as i’m planning to use 5 Anel devices.
Any help ?
