ohmicha
(Michael)
#1
I am using the http Binding to fetch values from a local weather station (with http cache). Even if I have set the log level to error
log:set error org.openhab.binding.http
I got lots of warnings - seems as for every refresh and value:
15:15:03.069 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:03.683 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:04.298 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:04.919 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:05.526 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:06.131 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:06.743 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
15:15:07.352 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
Any idea why this warning appears or why the log level seems to be ignored?
opus
(Jürgen Baginski)
#2
IMHO the level level desired has to be in capitals, like ERROR
You can check what is actually set by calling log:set
ohmicha
(Michael)
#3
No, same behaviour when I use the version in capitals:
log:set OFF org.openhab.binding.http
output:
16:37:57.820 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
16:37:58.428 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
16:37:59.037 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
16:37:59.651 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
16:38:00.260 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
seems as the console is also checking the possible values, as when I use a wrong value an error is returned
Error executing command: No enum constant org.apache.karaf.log.core.Level.OFF
btw: even wondering why off is not a valid level, as it is listed in the documentation:
http://docs.openhab.org/administration/logging.html
Dim
(Angelos)
#4
it’s in karaf 4.1.2
by the way: check if the log:set should be at the io bundle
rlkoshak
(Rich Koshak)
#5
you set the level for the wrong package. the error is coming from ???he.commons.httpclient.HttpMethodBase, not org.openhab.binding.http.
you might need to search the ESH repo to find this class to learn the first part of the package name.
ohmicha
(Michael)
#6
Thanks for the hint, it was
log:set error org.apache.commons.httpclient
I also checked in trace mode and seems as a setting of the weather station server
18:10:03.397 [TRACE] [he.commons.httpclient.HttpMethodBase] - enter HttpMethodBase.canResponseHaveBody(int)
18:10:03.943 [DEBUG] [he.commons.httpclient.HttpMethodBase] - Should NOT close connection in response to directive: Keep-Alive
18:10:03.945 [TRACE] [he.commons.httpclient.HttpConnection] - enter HttpConnection.isResponseAvailable()
18:10:03.947 [WARN ] [he.commons.httpclient.HttpMethodBase] - Stream closed
18:10:03.948 [TRACE] [he.commons.httpclient.HttpConnection] - enter HttpConnection.close()
18:10:03.950 [TRACE] [he.commons.httpclient.HttpConnection] - enter HttpConnection.closeSockedAndStreams()
18:10:03.952 [TRACE] [he.commons.httpclient.HttpConnection] - enter HttpConnection.releaseConnection()
