wartel
(Gerald Stieglbauer)
January 23, 2016, 11:43pm
1
seems I am unable to understand the syntax of the OSGI console.
I want to test my Squeezebox Boom. My identifier in the openhab.cfg is mySqueeze
However:
osgi> openhab > squeezeboxPause(“mySqueeze”)
is not accepted as an valid argument. What I am doing wrong?
Best regards,
Wartel
squeezeboxPause is not a script but an action. Unfortunately I don’t know if (or even how) it’s possible to pass an action command from the osgi console.
wartel
January 24, 2016, 4:41pm
3
There should be some recognition of the action command. For instance, if I write
it responds with
___ squeezeboxPause
Invalid number of arguments. Expected (String); line 1, column 0, length 15
If I write
openhab > squeezeboxPause(squeezeID)
where squeezeID is a String item it responds
squeezeboxPause( ___ squeezeID)
Incompatible types. Expected java.lang.String but was org.openhab.core.library.items.StringItem; line 1, column 16, length 9
If I just write
squeezeboxPause( ___ anitasqueeze)
Couldn’t resolve reference to JvmIdentifiableElement ‘anitasqueeze’.; line 1, column 16, length 12
So what is the right representation of a string here?
Best regards,
Wartel
Tjerk_W
(Tjerk W)
March 14, 2016, 11:44pm
4
I have a similar issue. However an answer to you: You cannot execute actions trough osgi, only scripts. But howto execute scripts, thats unclear to me, see: Controlling openhab from commandline
