Yaaaaay that was it! Everything is working like a Charm now. I am not
missing any IDs anymore.
Thx for your Time and Help.
So all of them have the right capabilities now or is anything missing?
I havenāt tried adding the TW bulbs yet because Iām still having problems with the RGBW timing out. It seems better. I was able to turn the RGBW lights onand off a bunch of times until they stopped and the same warnings appear
2017-04-04 01:10:00.182 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' to inbox.
2017-04-04 01:10:00.207 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lightify:bulb-rgbw:027d74c8:9F38060000261884' to inbox.
2017-04-04 01:11:08.283 [WARN ] [.lightify.internal.link.LightifyLink] - Packet content, sent: 1700003211000000332B060000261884010000000000000000, received: 11000000000100332B060000261884001E00
2017-04-04 01:11:08.289 [WARN ] [.lightify.internal.link.LightifyLink] - Status code: 0x11, command: LIGHT_SWITCH
2017-04-04 01:11:08.294 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occured while calling handler: java.lang.IllegalStateException: Illegal packet type: 0x0, command: LIGHT_SWITCH
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Illegal packet type: 0x0, command: LIGHT_SWITCH
at java.util.concurrent.FutureTask.report(FutureTask.java:122)[:1.8.0_121]
at java.util.concurrent.FutureTask.get(FutureTask.java:206)[:1.8.0_121]
at org.eclipse.smarthome.core.common.SafeMethodCaller.callAsynchronous(SafeMethodCaller.java:188)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:81)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller.call(SafeMethodCaller.java:65)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.thing.internal.ThingManager.receiveCommand(ThingManager.java:369)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
at org.eclipse.smarthome.core.items.events.AbstractItemEventSubscriber.receive(AbstractItemEventSubscriber.java:46)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:192)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.internal.events.OSGiEventManager$1.call(OSGiEventManager.java:1)[98:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:179)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Caused by: java.lang.IllegalStateException: Illegal packet type: 0x0, command: LIGHT_SWITCH
at org.openhab.binding.lightify.internal.link.LightifyLink.handleHeader(LightifyLink.java:367)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.internal.link.LightifyLink.onPacket(LightifyLink.java:181)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.internal.link.LightifyLink.readPacket(LightifyLink.java:385)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.internal.link.LightifyLink.perform(LightifyLink.java:157)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.internal.link.LightifyLink.performSwitch(LightifyLink.java:98)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.internal.link.LightifyLuminary.setSwitch(LightifyLuminary.java:43)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.handler.DeviceHandler.handlePowerSwitch(DeviceHandler.java:162)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.openhab.binding.lightify.handler.DeviceHandler.handleCommand(DeviceHandler.java:107)[183:org.openhab.binding.lightify:2.1.0.201704031709]
at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:372)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
at org.eclipse.smarthome.core.thing.internal.ThingManager$4.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b4]
... 5 more
2017-04-04 01:11:13.734 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing lightify:bulb-rgbw:027d74c8:332B060000261884 takes more than 5000ms for processing event
2017-04-04 01:11:13.741 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-04 01:11:13.741 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:11:18.751 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:11:18.751 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:11:18.755 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-04 01:11:23.763 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing lightify:bulb-rgbw:027d74c8:332B060000261884 takes more than 5000ms for processing event
2017-04-04 01:11:23.763 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:11:23.765 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:11:55.595 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:11:55.595 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:11:55.597 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-04 01:12:00.597 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:12:00.597 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:12:05.599 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:12:05.599 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:12:10.601 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:12:10.601 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:12:15.603 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:12:15.603 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:12:20.605 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:12:20.607 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:12:25.608 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:12:25.612 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:12:30.610 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:12:30.626 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:12:35.612 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:12:35.628 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:12:40.614 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:12:40.630 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:12:45.617 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:12:45.632 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:12:50.619 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:12:50.635 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:12:55.628 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:12:55.637 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:13:00.630 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:13:00.639 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:13:05.632 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
2017-04-04 01:13:05.641 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:13:10.634 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@1357cb9' takes more than 5000ms.
2017-04-04 01:13:10.642 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:13:15.646 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@e6c96a' takes more than 5000ms.
2017-04-04 01:13:15.646 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:13:20.648 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@71922e' takes more than 5000ms.
2017-04-04 01:13:20.654 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:13:25.651 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@1f32430' takes more than 5000ms.
2017-04-04 01:13:25.656 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:13:30.653 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@18be531' takes more than 5000ms.
2017-04-04 01:13:30.672 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@1517a3b' takes more than 5000ms.
BTW, any suggestions on how to continue to post to this thread? I tried to reply but got a warning that I exceeded the maximum number of replies for new users, so Iām editing this one instead. Itās going to make it really difficult to reply to your next reply.
Yeah everything is there. Thx again.
Am 03.04.2017 20:43 schrieb āChristoph Engelbertā <bot@community.openhab.org
Interesting you got the exception that a wrong packet was received and it seems right afterwards it starts to time out. So Iāll change it in a way, that Iāll just log the information but will just ignore the error. Still I wonder what happened here since so far Iāve never seen status code 0x11. Do you use zones? Did you try to turn on / off zones or bulbs itself?
PS: looking into the ānew user limitā issue
I have changed your level to ābasic userā, so you should be able to post here again. Otherwise, the other simplest solution to the problem is to engage yourself in other topics as well
Ok slightly updated version, exchanges exception with an log entry only and discard the message. I wonder if that fixes the issue, if it does, there seems to be a bug in openhab Anyhow first I want to get it stable for you
No, no zones, no TW bulbs, and even no other bindings or rules. Iām working with a clean openhab2 installation and have reset my osram network. Iām trying to keep the setup as simple as possible, get it working, and then slowly add to it to help identify any conflicts.
Thanks @Kai ! Iāve been waiting for someone like @noctarius to program the osram binding so that I could switch from SmartThings, and now Iām jumping on the openhab bandwagon.
Iāll try the new version out tonight and let you know how it goes. If it works consistently for a while, Iāll add the TW bulbs to the network and test those as well.
Same results unfortunately. After turning the lights on and off a few times, it stops responding. Even though they stop responding in openhab, I can switch to the OSRAM app and still control the lights, so I know that the bridge is still working.
2017-04-05 00:44:13.373 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-04-05 00:44:13.928 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-04-05 00:44:14.078 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-04-05 00:44:14.330 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-04-05 00:47:54.599 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lightify:gateway:027d74c8' to inbox.
2017-04-05 00:47:59.603 [INFO ] [.lightify.internal.link.LightifyLink] - Reconnecting to lightify gateway: 192.168.0.106:4000
2017-04-05 00:48:00.172 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' to inbox.
2017-04-05 00:48:00.201 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'lightify:bulb-rgbw:027d74c8:9F38060000261884' to inbox.
2017-04-05 00:48:22.828 [WARN ] [.lightify.internal.link.LightifyLink] - Packet content, sent: 1600006809000000332B0600002618840000000000000000, received: 09000000000100332B060000261884011E00
2017-04-05 00:48:22.830 [WARN ] [.lightify.internal.link.LightifyLink] - Status code: 0x9, command: STATUS_SINGLE
2017-04-05 00:48:22.832 [WARN ] [.lightify.internal.link.LightifyLink] - Illegal packet type: 0x0, command: STATUS_SINGLE
2017-04-05 00:49:56.729 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@c88eed' takes more than 5000ms.
2017-04-05 00:49:56.736 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-05 00:49:58.343 [WARN ] [.lightify.internal.link.LightifyLink] - Illegal packet type: 0x32, command: STATUS_SINGLE
2017-04-05 00:49:58.398 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@c88eed' takes more than 5000ms.
2017-04-05 00:49:58.398 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-05 00:50:03.418 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@c88eed' takes more than 5000ms.
2017-04-05 00:50:03.418 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing lightify:bulb-rgbw:027d74c8:332B060000261884 takes more than 5000ms for processing event
2017-04-05 00:50:08.435 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@117e5d4' takes more than 5000ms.
2017-04-05 00:50:08.436 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing 'lightify:bulb-rgbw:027d74c8:332B060000261884' takes more than 5000ms for processing event
2017-04-05 00:50:08.440 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@c88eed' takes more than 5000ms.
2017-04-05 00:50:13.442 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.ThingManager@c88eed' takes more than 5000ms.
2017-04-05 00:50:13.443 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.autoupdate.internal.AutoUpdateBinding@10e6af9' takes more than 5000ms.
2017-04-05 00:50:13.448 [WARN ] [ome.core.thing.internal.ThingManager] - Handler for thing lightify:bulb-rgbw:027d74c8:332B060000261884 takes more than 5000ms for processing event
2017-04-05 00:50:18.444 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@19c6827' takes more than 5000ms.
2017-04-05 00:50:19.452 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@19c6827' takes more than 5000ms.
2017-04-05 00:50:23.447 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@c3030d' takes more than 5000ms.
2017-04-05 00:50:24.454 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@c3030d' takes more than 5000ms.
2017-04-05 00:50:28.450 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@8272f3' takes more than 5000ms.
2017-04-05 00:50:29.458 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@117e5d4' takes more than 5000ms.
2017-04-05 00:50:33.452 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@117e5d4' takes more than 5000ms.
2017-04-05 00:50:34.460 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@19c6827' takes more than 5000ms.
Looking at the time you normally answer, are you located in the US? I wonder if thereās a difference in the firmware being distributed for Sylvania branded bulbs. Anyhow Iām happy Iāve added the āsent & received packetsā since I can debug the output and thanks for your awesome help and your time you invest!
Ok thatās weird, there are actually 2 bytes missing in the header of your response packet. Thatās why it fails. What is the firmware version of your gateway / lights?
Yes, US, Eastern (GMT-5) time zone. It says Gateway Wifi version 1.1.3.37, Zigbee 1.2.0.68, and Osram version 1.8.0. Itās the latest version available.
No, thank you for the time youāre investing. I really appreciate it. Let me know if thereās anything I can do or information I can supply to help.
Ok gateway version matches, I know the firmware is slightly different, since US has itās own cloud instance. What is the light firmware (however I donāt expect that to be the issue) and what OpenHAB version do you use? 2.0.0?
Iām not sure of the light version. They seem to have hidden the bulb version number from the System Update screen. I know thereās no updates available. Iām using the OpenHABianPi v1.2 image openhabianpi-ua-netinst-20170317-gitbd31755f-crc88a5ae46.img. I think thatās 2.0.0, but canāt confirm right now.
Whatās the appās distributor? OSRAM or Sylvania? There might be more difference than expected
OSRAM running on Android 7.0
Ok Iāll put together a special version tomorrow for you, capturing all traffic between the gateway and openhabā¦ this is certainly weird. I wonder if your openhab version works somehow differently in terms of threading, since itās funny that some bytes are missing.
Hey, sorry itāll take a few days more, as Iām on the road at the moment which means I cannot try if the changed code still works.
