Stoatwblr
(Stoatwblr)
1
I’ve got some Tuya radiator valves setup here as MQTT devices which return “device/child_lock” as LOCKED or UNLOCKED
I want to define that as a switch
The problem is that the topic device/set/child_lock needs LOCK or UNLOCK
Does anyone know what the output transformation syntax is for this?
(as these are likely to become more commonly used it might need a FAQ)
pacive
(Anders Alfredsson)
2
Just use a map transformation with
ON=LOCK
OFF=UNLOCK
in the .map file. (Or the other way around if that’s how it’s set up)
rossko57
(Rossko57)
3
MQTT switch type channels provide a “mini-map-transform” in the form of the on=
and off=
parameters. It’s in the docs.
