- Platform information:
- Hardware: Raspberry Pi2
- OS: Raspbian GNU/Linux 7
- Java Java™ SE Runtime Environment (build 1.8.0-b132)
- openHAB version: 2.2.0
I have integrated an ESP8266 with attached reed relay into my local Wifi network. It reports the state of the reed relay via a local running WebServer on port 80. I can access this web service via a browser on my desktop machine on http://192.168.178.49/status.
Now I have configured a service:
reed.url=http://192.168.178.49/status
reed.updateInterval=5000
Additionally I have configured an item:
String reeditem { http="<[reed:10000:JSONPATH($.state)]" }
Beyond that I have integrated it into my sitemap:
sitemap my label=“ASitemap” {
Frame label=“Fensterkontakte” {
Text item=reeditem label=“Fenster Bad Dach [%s]”
This works well, as long as my ESP8266 is running. When I turn off its power, the Basic UI still reports the old state. It does not get updated for hours. I don’t see any error that the web service of the ESP8266 is no longer running nor do I see a timestamp that reports the last update of the HTTP binding. Hence, as a user I cannot say that something is wrong, as the openHAB UI makes me think the reed relay is still closed.
Therefore my question: Is it possible to output in the UI (Basic UI/Android app) the timestamp of the last update the openHAB server received from the ESP8266 or an error message if a number of polls failed?
Thanks in advance.
Best Regards
Martin Mois
