shouldn’t be a problem with fputcsv!
…yes, I’m German, near Augsburg.
I was looking for a Weather Station and found this topic.
Thank you very much for sharing!
I’m trying to get this running in docker with Dockerfile:
FROM php:7.2-apache
COPY . /var/www/html
EXPOSE 80
CMD apache2-foreground
If i omit the CMD, the docker container is stopped with:
[mpm_prefork:notice] [pid 1] AH00170: caught SIGWINCH, shutting down gracefully
It runs, and gives the following output on every update
10.0.3.1 - - [11/Jun/2020:20:51:33 +0000] “GET / HTTP/1.1” 200 241 “-” “python-requests/2.18.4”
Is it supposed to look like this?
However nothing happens in openhab (REST API is working, and $url is correct)
Any suggestion how to solve this, please?
I have the same problem. The weather station calls the script every 20 seconds, but no values in openhab2. The rest api has tested and was working with this command:
curl -X POST --header “Content-Type: text/plain” --header “Accept: application/json” -d “ON” “http://192.168.xxx.xxx:8080/rest/items/Esszimmerlicht”
There were some issues I had to solve:
The 10.0.3.1 calls are from something else.
So this is the modified working PHP-file:wetterstation.php.txt (3.6 KB)
Thankx @Andreas_Pircher, you’re absolutely right, I somehow managed to not include the functions for calculating the metric values… I just updated the code in my initial post (I rounded on two digits)
And yes, one important thing is to type in the path to the script in the App with the trailing ?
at the end, otherwise you won’t get the GET-attributes… (I also just updated the initial screenshot)
I discovered a calculation error in @binderth’s script I was using for over a year now …
There was a in2cm function, but in Openhab I display mm.
This is the updated version: wetterstation.php.txt (4.4 KB)
I’m using it since forever!
Thanks for spotting it! I’m not sure how that slipped. Perhaps something I configured in OH2 but in OH3 it’s different now… anyways: thanks!
Hi all,
Just thinking to order one of these weather stations.
Do you think this script will work with
Or do you have a correct link to one of the compatible stations as I get a few results for WS3500
Thanks in advance
Koen
This is the exact weather station I’m using since - with my script!
Okay,
Thx for your quick respons. I’m gonna order this one
Finally a have some spare time to get this project going.
What would be the easiest straight forward methode of creating this website? webstation or would wordpress maybe easier?
it isn’t a website, you only need an PHP parser. if you’re running a Synology NAS you can use webstation with active PHP of course. or any other PHP-capable webserver… wordpress for pnly this purpuse would be the definition of overkill
Hello to all,
thank you for script it works on my side too.
I only recognized that these two items were not updated:
DateTime Weatherstation_dateutc "Uhrzeit" <temperature> (gWeather, Wetter)
Number Weatherstation_elev "Elevation [%.1f]" <temperature> (gWeather, Wetter)
Is it the same on your setup?
@binderth: In the php file I found the “Beispiel von Wetterstation”. How did you read out this example from your weather station? I have no experience with PHP but maybe this script is good starting point for me.
// 192.168.0.119 - - [12/Jun/2020:20:29:37 +0000] "GET /wetterstation.php?ID=1&PASSWORD=1&indoortempf=81.1&tempf=70.5&dewptf=52.7&windchillf=70.5&indoorhumidity=40&humidity=53&windspeedmph=1.6&windgustmph=2.2&winddir=79&absbaromin=29.064&baromin=29.903&rainin=0.000&dailyrainin=0.000&weeklyrainin=0.000&monthlyrainin=0.000&solarradiation=0.00&UV=0&dateutc=2020-06-12%2020:29:37&softwaretype=EasyWeatherV1.5.0&action=updateraw&realtime=1&rtfreq=5 HTTP/1.0" 200 913 "-" "-"
first of all, the linked PHP-script in #12 is the starting point:
What the script does is the following:
foreach ($_GET as $key => $value) {
This loops through all GET-parameters, the weather station sends.
switch (substr($key, -3)) {
this one looks for the las three digits of the key-string (e.g. indoortempf) and converts some units to “the correct” units.
if there’s no unit, it’s default just sends the value.
function sendOH2Command($item, $data) {
this one sends the value to openHAB via REST API.
So, if you’re missing a value, make sure, you have the corresponding item available in your items, and keep in mind:
$weatherprefix = "Weatherstation_"; // if you have a prefix in your OH2 items configuration
endOH2Command($weatherprefix.$key, $value);
so, the item name should bei Weatherstation_elev and the weather station should send a key “elev” and one “dateutc”.
My weather station (EasyWeather-WIFI50DD) sends the “dateutc”, but not “elev”.
Thank this helps me a lot.
You have mentioned that your weather station sends not the “elev” key.
How do you request the data/key from your weather station?
Can I just type in the browser e.g.
http://my_weather_station_ip/getData
I would like to check what my weather stations sends out, maybe the name is not matching.
But I do not know how to read out these information from the weather station
No, you can’t. Please read the thread from the beginning (I know, annoying, if there’s info splattered across).
You have to configure the weather station in the “WS View”-App to call a certain script. It will then do that periodically - you set the seconds in the “upload interval”.
you can
easiest would be 1. I guess, if you know, where it is.
Also, this is, what my WS3500 aka WIFI50DD sends (Firmware: EasyWeathev1.6.4) - already converted to JSON-format
"ID": "123",
"PASSWORD": "987",
"indoortempf": "78.1",
"tempf": "84.4",
"dewptf": "56.8",
"windchillf": "84.4",
"indoorhumidity": "47",
"humidity": "39",
"windspeedmph": "1.8",
"windgustmph": "3.4",
"winddir": "165",
"absbaromin": "28.358",
"baromin": "30.036",
"rainin": "0.000",
"dailyrainin": "0.000",
"weeklyrainin": "0.000",
"monthlyrainin": "0.791",
"solarradiation": "577.79",
"UV": "5",
"dateutc": "2022-07-28 13:36:02",
"softwaretype": "EasyWeatherV1.6.4",
"action": "updateraw",
"realtime": "1",
"rtfreq": "5"
Thanks, for your tip.
I have added this to the php file:
My first php code but it works
// write data from weather station into txt file
$result = array($_GET);
file_put_contents("weatherstation_data.txt",print_r($result, true));
Here my data:
Array
[0] => Array
[ID] => XXX
[PASSWORD] => XXXX
[tempf] => 87.6
[humidity] => 37
[dewptf] => 58.3
[windchillf] => 87.6
[winddir] => 280
[windspeedmph] => 3.80
[windgustmph] => 5.82
[rainin] => 0.000
[dailyrainin] => 0.000
[weeklyrainin] => 0.000
[monthlyrainin] => 0.071
[yearlyrainin] => -9999
[totalrainin] => 0.071
[solarradiation] => 225.11
[UV] => 2
[indoortempf] => 80.8
[indoorhumidity] => 43
[absbaromin] => 29.211
[baromin] => 29.716
[lowbatt] => 0
[dateutc] => now
[softwaretype] => EasyWeatherPro_V5.0.7
[action] => updateraw
[realtime] => 1
[rtfreq] => 5
Here my info regarding the weatherstation Sainlogic WS3500 built 05.2022.
When I look into WSView Plus app the weather station is called "EasyWeatherPro-0FDC2.1
We both have no “elev” and my “dateutc” is only a string with now.
I have created my additional data and changed the the Data to String, makes no sense but I get now all data provided by the weather station;-)
Number Weatherstation_lowbatt "Batterie" <temperature> (gWeather, Wetter)
Number:Length Weatherstation_yearlyrain "Niederschlag/Jahr [%.1f mm]" <rain> (gWeatherHeight, Wetter)
**String** Weatherstation_dateutc "Uhrzeit" <temperature> (gWeather, Wetter)
I think, your Firmware has an bug with “now” instead of a UTC-timestamp!
other than that, it looks good! And beware of your skills in scripting growing over time using openHAB!
Hi all, for anyone looking to use the ECOWITT output type. Here is a php that performs well. It’s just a modification of @binderth’s amazing code.
You’ll need to use this if you need data such as additional sensors and battery data, which aren’t supported by the wunderground format.
I’ve also included a corresponding items file. I have one additional sensor on CH2. You can add extras as you have configured.
I’ve also included a handy function at the top, comment this back in to troubleshoot and see the values your php file is receiving.
<?php
// Code to log your Ecowitt output to a file for exploration and troubleshooting.
// You'll need to create the directory /var/log/weather/ and give it permissions.
// $date = date_create();
// $handle = fopen("/var/log/weather/" . date_timestamp_get($date), "w");
// $result = print_r($_POST, true);
// print_r(error_get_last());
// fwrite($handle, $result);
// fclose($handle);
// Beispiel von Wetteratation
// resends all GET-Values directly to OH2 API
foreach ($_POST as $key => $value) {
// looking for suffixes and redirecting them
/* Weatherunderground format looks like this:
* ID ID (configuratble in the App)
* PASSWORD KEY (configurable in the App)
* indoortempf in Fahrenheit
* windchillf in Fahrenheit
* indoorhumidity in percent
* humidity in pfpro_cleanup
* windspeedmph in mp/h
* windgustmph in mp/h
* winddir in degrees
* absbaromin in inch of mercury
* baromin in inch of mercury
* rainin in inch
* dailyrainin in inch
* weeklyrainin in inch
* monthlyrainin in inch
* solarradiation in W/m2
* UV in index (0 - 11)
* dateutc current date (UTC)
* softwaretype used software
* action usually "updateraw"
* realtime using real-time updates (0/1)
* rtfreq update frequency (configurable in the App)
as seen here, with the last character(s) of a attribute you can tell, which unit is used
switch ($key) {
case "tempinf":
case "tempf":
case "temp1f":
case "temp2f":
case "temp3f":
case "temp4f":
case "temp5f":
case "temp6f":
case "temp7f":
case "temp8f":
// case ""
// unit is in Fahrenheit (remove "f")
if(f2c($value) < -40) { //Filter für unmögliche Werte
sendOH2Command($weatherprefix . "error", "Filter: " . $key . "=" . $value . "(" . f2c($value) . "°C)");
else {
sendOH2Command($weatherprefix.str_replace("f", "", $key), f2c($value));
break;
// case "ptf":
// // unit is in Fahrenheit also (remove "f")
// if(f2c($value) > -40) //Filter für unmögliche Werte
// sendOH2Command($weatherprefix.str_replace("ptf", "pt", $key), f2c($value));
// else
// sendOH2Command($weatherprefix . "error", "Filter: " . $key . "=" . $value . "(" . f2c($value) . "°C)");
// break;
// case "llf":
// sendOH2Command($weatherprefix.str_replace("llf", "ll", $key), f2c($value));
// else
// break;
case "baromrelin":
case "baromabsin":
// unit is in inHg (remove "min")
sendOH2Command($weatherprefix.str_replace("in", "", $key), inHG2hPa($value));
break;
case "rainratein":
case "eventrainin":
case "hourlyrainin":
case "dailyrainin":
case "weeklyrainin":
case "monthlyrainin":
case "yearlyrainin":
// unit is in inch (remove "in" from end of field)
sendOH2Command($weatherprefix.substr($key, 0, -2), in2mm($value));
break;
case "windspeedmph":
case "windspdmph_avg10m":
case "windgustmph":
case "maxdailygust ":
// unit is in mph (remove "mph")
sendOH2Command($weatherprefix.str_replace("mph", "", $key), mph2kmh($value));
break;
case "utc":
// unit is in UTC
sendOH2Command($weatherprefix.$key, str2UTC($value)."");
break;
default:
// everything else: not a unit, or percent or string
if($value > -1000) //Filter für unmögliche Werte
sendOH2Command($weatherprefix.$key, $value);
else
sendOH2Command($weatherprefix . "error", "Filter: " . $key . " = " . $value);
$url = "http://openhabian:8080/rest/items/" . $item;
// $url = "http://localhost:32080/rest/items/" . $item; //geht mit localhost nicht
$options = array(
'http' => array(
'header' => "Content-type: text/plain\r\n",
'method' => 'POST',
'content' => '' . $data //http_build_query($data),
$context = stream_context_create($options);
$result = file_get_contents($url, false, $context);
return $result;
function str2UTC($given_value) {
return str_replace(" ", "T", $given_value);
function mph2kmh($given_value) {
return '' . round( floatval($given_value) * 1.60934, 1);
function in2mm($given_value) {
return '' . round( floatval($given_value) * 25.4, 1);
function inHG2hPa($given_value) {
return '' . round( floatval($given_value) * 33.8639 , 1); //1 inHG = 3386,39 Pa, Bespielwert: 29.064 sollte ca 985 sein
function f2c($given_value) {
return '' . round( (5.0 / 9 * (floatval($given_value) - 32 )), 1);
String Weatherstation_JSON "Weatherstation JSON"
Group Weather "Weather Observations" (All)
// Config Info
// String Weatherstation_PASSKEY "id"
String Weatherstation_PASSKEY "Key / Passsword"
String Weatherstation_stationtype "Software Version"
String Weatherstation_model "Station Model"
DateTime Weatherstation_dateutc "Date" <temperature> (gWeather, Weather)
String Weatherstation_softwaretype "Software" <temperature> (gWeather, Weather)
String Weatherstation_action "WeatherAction" <temperature> (gWeather, Weather)
String Weatherstation_realtime "Realtime" <temperature> (gWeather, Weather)
String Weatherstation_rtfreq "Updatefrequency" <temperature> (gWeather, Weather)
// Temperature
Number:Temperature Weatherstation_tempin "Indoor Temperature [%.1f %unit%]" <temperature> (gWeatherTemp, Weather)
Number:Temperature Weatherstation_temp "Outdoor Temperature [%.1f %unit%]" <temperature> (gWeatherTemp, Weather)
Number:Temperature Weatherstation_dewpt "Dew Point [%.1f %unit%]" <temperature> (gWeatherTemp, Weather)
Number:Temperature Weatherstation_windchill "Windchill [%.1f %unit%]" <temperature> (gWeatherTemp, Weather)
Number:Temperature Weatherstation_temp2 "Greenhouse Temp [%.1f %unit%]" <temperature> (gWeatherTemp, Weather)
// Barometer
Number:Pressure Weatherstation_baromrel "Barometer min [%.1f %unit%]" <temperature> (gWeatherPressure, Weather)
Number:Pressure Weatherstation_baromabs "Abs. Barometer min [%.1f %unit%]" <temperature> (gWeatherPressure, Weather)
// Rain
Number:Length Weatherstation_rainrate "Rain [%.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_eventrain "Rain Event [%.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_hourlyrain "Rain Hourly [%.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_dailyrain "Rain Daily [%.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_weeklyrain "Rain Weekly %.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_monthlyrain "Rain Monthly [%.1f mm]" <temperature> (gWeatherHeight, Weather)
Number:Length Weatherstation_yearlyrain "Rain Yearly [%.1f mm]" <temperature> (gWeatherHeight, Weather)
// Wind
String Weatherstation_winddir "Wind Direction" <temperature> (gWeather, Weather)
String Weatherstation_winddir_avg10m "Wind Speed [%.1f %unit%]" <temperature> (gWeatherSpeed, Weather)
Number:Speed Weatherstation_windspeed "Wind Speed [%.1f %unit%]" <temperature> (gWeatherSpeed, Weather)
Number:Speed Weatherstation_windspd_avg10m "Wind Speed (Ave 10 mins) [%.1f %unit%]" <temperature> (gWeatherSpeed, Weather)
Number:Speed Weatherstation_windgust "Wing Gust [%.1f %unit%]" <temperature> (gWeatherSpeed, Weather)
Number:Speed Weatherstation_maxdailygust "Wing Gust (Max Daily) [%.1f %unit%]" <temperature> (gWeatherSpeed, Weather)
// Humidity
Number Weatherstation_humidity "Outdoor Humidity [%.1f %%]" <temperature> (gWeather, Weather)
Number Weatherstation_humidityin "Indoor Humidity [%.1f %%]" <temperature> (gWeather, Weather)
Number Weatherstation_humidity2 "Greenhouse Humidity [%.1f %%]" <temperature> (gWeather, Weather)
// Solar Info
Number Weatherstation_solarradiation "Solar Radiation [%.1f]" <temperature> (gWeather, Weather)
Number Weatherstation_uv "UV-Index [%.1f]" <temperature> (gWeather, Weather)
//Battery
Number Weatherstation_wh65batt "WH65 Battery" <temperature> (gWeather, Weather)
Number Weatherstation_wh25batt "Indoor Sensor Battery [%.1f]" <temperature> (gWeather, Weather)
Number Weatherstation_batt2 "Greenhouse Sensor Battery[%.1f]" <temperature> (gWeather, Weather)
