Here is a collection of radio controlled home automation eco systems put together by an IoT beginner in order to gain an idea which systems to buy.
Would be nice if you could add on systems and comment on my findings in order to create one thread giving beginners an over few about all relevant available systems and their pros and cons. Info about all available bindings for openHAB can be found here.
Z-Wave and Z-Wave +
• Used by many openHAB users
• Wide range of products from different vendors, fast growing
• Mesh system > cable wired components act as repeaters
• Sub GHz system generic
• No separate base unit needed
• Things report back to Z-Wave stick>openHAB
• Firmware not easy to update trough openHAB
• Some things reported to have high battery consumption
• Main brands: Fibaro, Aeotec, Qubino, Z-Wave.ME, Popp,
MomeMatic, HomeMatic IP
• Wide generic range
• No mesh system but repeaters possible
• Need base CCU2 or alternative to work with openHAB
• Firmware easy update via CCU2 interface
• Generic to eQ-3
• Meanwhile more expensive than most Z-Wave things
• Homematic and Homematic IP things can be mixed operated at a base unit CCU2
EnOcean
• Relative wide range offered by different vendors
• No batteries needed for non-wired things (energy harvesting)
• Relatively expensive compared to Z-Wave and HomeMatic
• Main brands: Eltako, Peha,
ZigBee
• Mainly for lighting applications. Others available
• Mesh system possible other topologies possible
• USB-Stick and gateways available
• Limited interoperability between different vendors/systems
• Main brands: Philips Hue, Ikea, Osram Lightify, Busch-Jaeger, Samsung SmartThings
Insteon
• Complete system
• Hardly available in Europe
• Mesh system
Sonoff
• Used by a growing number of openHAB enthusiasts
• Relatively small portfolio for now
• Does need Tasmota firmware flash and MQTT broker to work with openHAB
• Is using WiFi standard
• Very low price points
• Hardly available in Europe (at least in Germany)
• Can be ordered directly at the vendors homepage - ITEAD
MiLight
• Mainly for lighting applications limited offering of things
• No mesh system?
• Things do not report back
• Relatively cheap
Max
• Only heating system control (thermostatic radiator heads, thermostats, window contacts)
• Generic to eQ-3
• No mesh system no repeaters
• Relatively cheap
WiFi systems - general
• Can use existing WiFi network
• Relatively easy to set up
• Relatively high energy consumption – battery operated devices problematic
• Various generic systems
• Need to list in particular > brands and standards
• Known systems: AVM Fritz!Dect, TP-Link BlueTooth (low energy)
• Is using standard or low energy BlueToth
• Relatively short range
BlueTooth (low energy) - general
