Tries to install subj. All working well except OH main UI administrator login (bottom left corner icon). When I pressed under cloud host - got 404 with ‘Cannot GET /auth’ message.
My setup:
nginx container forward all wan traff to ‘cloud container’ 3000 port
Cloud container with node app (latest from github) - 3000 port
OH3.1 container with 8080 port
Looks like cloud container does not proxy traf for /auth url but I don’t know why
Only for me or well known bug? )
rpwong
(Russ)
July 23, 2021, 8:24pm
3
There aren’t many people who use their own clouds instead of myopenhab (or reverse proxy). Of the small number who do, it’s possible that none of them have been here recently to see your post.
post your nginx config so that others could review it.
Front NGINX (portf-forwarder from ISP)
root@front:~# cat /etc/nginx/sites-enabled/openhab
# openHABian NGINX Confiuration #
## Redirection
#REDIR server {
#REDIR listen 80;
#REDIR server_name DOMAINNAME;
#REDIR return 301 https://$server_name$request_uri;
#REDIR }
## Reverse Proxy to openHAB
server {
#SSL listen 443 ssl;
server_name <secured>;
client_max_body_size 300m;
#SSL add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
# Cross-Origin Resource Sharing.
#add_header Set-Cookie X-OPENHAB-AUTH-HEADER=1;
#add_header 'Access-Control-Allow-Origin' '*' always; # make sure that also a 400 response works
#add_header 'Access-Control-Allow_Credentials' 'true' always;
#add_header 'Access-Control-Allow-Headers' 'Authorization,Accept,Origin,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range,Range' always;
#add_header 'Access-Control-Allow-Methods' 'GET,POST,OPTIONS,PUT,DELETE,PATCH' always;
## Secure Certificate Locations
#CERT ssl_certificate CERTPATH;
#CERT ssl_certificate_key KEYPATH;
location / {
proxy_pass http://192.168.10.71:3000/;
#proxy_buffering off; # openHAB supports non-buffering specifically for SSEs now
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr ;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for ;
proxy_set_header X-Forwarded-Proto https;
listen 443 ssl http2; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/<secured>/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/<secured>/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = <secured>) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
