setup owntrack trough private http , it work great, i find 2 modes to run , one is long movement and the second is very accurate , if i set the long movement i have no trigger IN/OUT from home.
If i set (on the App) precise surveillance , it work perfectly but…i see on openhab log every each second a update , this is a lot of data 24/24 on each second …even if i don’t move …so any trick to set this more…"Eco friendly " ?
thanks for your sharing
As you know it works to relax precision why don’t you go with that.
And this question isn’t on openHAB so please go ask over in the owntracks forum and report back here.
Right i try to find , thanks for your reply
