I’ve been using the GPSTracker binding with Owntracks on my Android phone for many years but a few days it stopped working - no updates received from my phone.
After quite a bit of digging I came across this issue on Github - Issue · GitHub
It seems a recent update of Owntracks has broken things for a couple of servers (GPSTracker included). I’ve manually installed version 2.5.6 of Owntracks as a workaround.
I exported my settings in Owntracks then uninstalled the app on my phone.
Then downloaded the 2.5.6 release apk file from Release v2.5.6 · owntracks/android · GitHub and installed it (you need Developer mode enabled on your phone to do this). After opening I imported the settings I previously saved.
Looks like the binding already responds correctly. And as I wrote, I don’t have an issue. I tested with another Android device with 2.5.9 as well… I wonder what’s the difference here.
There’s at least an issue with the Owntracks Android app, which has been fixed. But that fix won’t be shipped until 2.5.10, of course. Or at least until the next beta release.
A separate issue with the binding is possible, but let’s first see.
I uninstalled the manually installed APK, and installed OwnTracks beta via Google Play, and it seems to work! (Strangely, this beta app claims to be 2.5.9, but I assume this is wrong.)
I again encountered problems, although I don’t understand why:
I did some more digging, and found out that there is/was indeed a problem with the binding, and a fix has been merged:
(Of course, this fix won’t be out until OH5.2, so if you want to use it before then, you’ll have to compile your own jar. Or use the one I built (see attached - you’ll have to remove the .txt extension; uploading a .jar file isn’t possible).
