Hi there,
after hours of of researching I feel a bit unsure about what to do. I own a couple of new milights and wonder what workarounds are (still) available to get these running. Correct me if I got sth. wrong here.
Some time ago you didnt need a milight-box to get them work. Not anymore
The whole Hue approach needs also a pre-config/pairing
Tried a bridge emu (milights-bridge) but also outdated and not working, install and test openmili(ght) atm
For the DIY ESP8266-Hub I also need more parts. But as I use some flashed plugs/bulbs with Tasmota/Sonoff firmware, I wonder if I could utilize this already existing ESP plattform. At least my noobish look at the manual didnt find a technical counterargument there.
Once they are integrated they will talk mqtt, so a hub wont be needed in the future anyway. Ah, and I have more than remotes I try to get rid of, so no interface here, too
KeLvin
Not yet as my technical understanding ends here and I dont know what really to do/substitute here when changing generic procedures (e.g. OTA instead of USB) due to another ESP Board (I also got a WeMo Insight here that has a ESP8266 Board, too).
Also was unsure because of this:
If you get a bare ESP8266 module, you’ll need to figure out how to power it (you’ll likely need a voltage regulator),
But I think I will get me a NRF24L01 while trying to figure out how to use this setup.
Furthermore I stumbled over the RPIeasy project. After a short research it can emulate a “ESPeasy P2P” Module… whatever this means.
I feared that =D
A bit of Background:
My endless “Home Cinema Automation” project slowly reaches a new milestone. I use a harmony hub for tons of technique and am working on an integration of mycroft.ai (DIY Virtual Assistant) for speech control.
One thing I try to achieve is a genuine implementation of the different bulbs I have: Some Tasmota flashed Tuya Bulbs, some proprietary IR based bulbs (Jedi Lighting iDual) and some new Milights. For the time being I will control the IR Bulbs with the Harmony Hub+OH2 as I have 4 of them and they are pretty cheap for lumen/Euro.
And then?
Going with diyHUE, as I use Kodi, OH2 and a Harmony who are supported
Getting a dedicated IR-MQTT transponder working (for OH2) for a more MQTT based config
ATM I prefere a mix: A Hue Interface for a fake Ambilight and MQTT for Voice/Automation.
For every approach I first need to integrate the new milights, but it may help finding the proper way to go here
I will buy a NRF24L01 later and depending on how far I come I will order a probable cheap milight-controller for a first setup and installation.
Cheers and Thanks
Kelvin
