The Sitemap worked in Chrome. Ok.
But the TV do not react and I get this lines in the terminal window:
Cannot retrieve item LivingRoom_TV for widget org.openhab.model.sitemap.Group
And if I use the Switch I get:
Received command ‘TOGGLE’ for item ‘LivinRoom_TV’, but the item does not exist in the registriy
Received command ‘TOGGLE’ for item ‘D1’, but the item does not exist in the registriy
Hey Rossko57,
I changed the name of binding and item. Check! But it doesn’t worked. Than…
Hello Watou,
I looked at the demo.sitemape and at the demo.items… I read something…
And than there was a point:
All item definition files have to have the file extension .items. Just create a new file called thenameyouwish.items.<<
So I check my files an find panasonic.item without “S”…
First error found! Yeah!
But now I can’t edit the item(s)-Files into the designer… now I use Notepad# - it works fine.
In the Sitemap I can switch the switches - push the buttons - but nothing happens…
“oprnhsb.cfg”
################################ Panasonic TV Binding #######################################
IP address of a Panasonic TV instance
panasonictv:TV=192.168.0.50
I think it should possible to power on the TV. But nothing happens.
I think it should possible to change the channel. But nothing happens.
It didn’t work even if the TV on or off…
Please send me a hint or better a part of a solution…
Many Thanks
I have managed to get a Panasonic TV working with all the controls except to get the Power on.
It appears to be offline as soon as I turn it off. I might have to set up an IR Blaster hooked into openHAB s a power switch for it.
