Dear Community,
Greetings, are these button working with the system?
https://www.vesternet.com/yale-smart-living-easy-fit-panic-button
Dear Community,
In theory you could make them work with something like: http://www.anarduino.com/details.jsp?pid=175
Note: The Yale says that it is using a proprietary protocol on 868Mhz so this may not work
The 2GIG is operating at 433MHz
Check: Binding for 868MHz Transceiver? (and many other threads on 433/868)
If you want to keep it simple: go Z-Wave with https://www.fibaro.com/en/products/the-button/ (or a similar Z-Wave button)
Fibaro button is little expensive than these if you need set of them.
I have question: when Fibaro switch2 connected to normal wall switch. If I pressed the wall switch can I get notification into the openHAB?
It will cost you the same in material and time to build a 433+868 solution… plus the headache and troubleshooting
Of course yes.
I would use a simple wireless doorbell button on 433Mhz
How to integrate it with openHAB?
What is the different between 433mhz and 868mhz. I mean as I understand from your reply if its 433 it can be integrated but if 868 it cannot, but Z-wave frequency is 868?
I use RFLink:RFLink Gateway - HomeAutomation
Or a simple RF receiver on a raspberry pi: https://www.instructables.com/id/Super-Simple-Raspberry-Pi-433MHz-Home-Automation/
It’s both about the RF protocol and also about the RF frequency
Z-Wave (in EU) does operate at 868.42 MHz but the Yale button is not a Z-Wave device. It uses a proprietary protocol to communicate with the Yale alarm system.
Both (433 + 868) can be integrated using the proper type of device with the proper firmware. There are many options out there. 433+868 are commonly used because they are unlicensed frequencies.
I know about this, my concern was when you mention that Yale uses 868 so this may not work
I assume this will work as well
I am worried about their protocol. They don’t advertise any info and it is specified that it is proprietary. In this case, even if you have a 868 transceiver, maybe you won’t be able to “decode” it.
Since the purpose of this specific button is to connect to your Alarm System (like other wireless endpoints like a PIR), I would expect that they use some kind of FSK (rolling codes) and other functionalities (like anti-jamming, etc) in their RF protocol, so it won’t be easy to use this (otherwise buglers would do the same easily )
