WuGGu
(Martin)
1
- Platform information:
- Hardware: Raspberry Pi3
- OS: openhabian
Hi everyone,
i added some Dimmer Items for the DMX Binding to control Brightness of some fixtures.
But when i klick on the Dimmer Fader in the Paper UI it not switched to 75% instead it shows 75.68627450980392268320429138839244842529296875 %.
Later i want to display this value over rest API on a small display and it looks awful.
Is there a way to set up fixed 100 steps, so only "clean" values where displayed?
Best regards
wuggu
H102
(CM6.5 H102)
2
What does the item config look like?
vzorglub
(Vincent Regaud)
3
Ignore the PaperUI
It is not meant for daily use but admin purposes
Use a sitemap
WuGGu
(Martin)
4
Even when i switch with the sliders in HABPanel the values are like 65.234682035498620348% not just 65%.
vzorglub
(Vincent Regaud)
5
You need to format the item
Use %d %
