I changed some of the links to my sensors inside paper UI. After a power outage the links changed back to their previous settings, is there a way to permanently make the change so that in the event of a power outage again everything remains the same. I know I need to get a UPS
When you make a change in PaperUI, the changes are immediately saved to disk. So one of two things is going on. Your SD card is worn out meaning that lots of stuff you are โwritingโ to disk are not actually being saved and the next time you reboot it will revert. Or the power outage corrupted the file system and lost your changes.
