I am new to openhab and configured all with Paper UI. Now I try to use Google Home and I learned that the Item need a .item file for the tags to be present.
Can I now configure the Bindings and Things in Paper UI and the Item in the .item file?
If yes, I am not able to create an example for this:
This looks like you are using the 2.x Squeezebox Binding. So that means:
You may also link an Item with a Channel using the .items file located in the OPENHAB_CFBG/items/ folder. Information about available Channels and options can be found in the Binding readme or discovered via Paper UI.
In Paper UI select a Thing to learn about Channels it supports.
Linking an Item to a Channel is of the form {channel=“channel id”}.
When you browse to the Thing in PaperUI it lists all the Channels. You can find the channel id and even copy that ID to the clip board by clicking on the little squares icon.
I googled some examples and there it was different…
I guess I even can create two items with the same purpose like:
Switch squeezeTransporterPowerGoogleHome “Transporter” [“Switchable”] {channel="squeransportesqueezeboxplayer_0d3f82da_000420201034_power_}
