Thank’s for your advice,
Yes, to the very end.
I have had everything running, same bindings etc. with the version Eclipse 19-03 and also an another(older i suppose build), but I had to do a new installation due to some trouble with this former installation
In development environment, no binding is installable the same way as in prod version. You have to include the bindings you want to activate in the pom.xml.
This is so strange, I started this thread in last Friday after a lot of negativ tries to have PaperUI work as expected.
I have then done nothing, (I have been away from home), until today Sunday and when I start Paper UI today will I see the binding Astro just as expected. This is so weird, I will be back if I find some reason to what has happend.
Thank’ s to all so far, Basse
