It is called exactly like this:
It seems like OpenHAB just doesn’t recognize my rule…
I get the following information out of my log - does it have to do with the rule?
It says something about the Humidity and Temperature, but in BasicUI, I can see the Humidity and Temperature…
2019-04-19 17:39:27.589 [vent.ItemStateChangedEvent] - mqtt_topic_steckdose_stube_Watt changed from 4 to 31
2019-04-19 17:39:37.496 [vent.ItemStateChangedEvent] - mqtt_topic_steckdose_stube_Uptime changed from 0T10:30:15 to 0T10:30:25
2019-04-19 17:39:37.570 [vent.ItemStateChangedEvent] - mqtt_topic_steckdose_stube_Luftfeuchtigkeit changed from 29.4 to 29.3
2019-04-19 17:39:37.579 [vent.ItemStateChangedEvent] - mqtt_topic_steckdose_stube_Watt changed from 31 to 30
2019-04-19 17:39:41.478 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.AM2301.Humidity' in '{"Time":"2019-04-19T16:39:41","ENERGY":{"TotalStartTime":"2019-04-05T17:16:13","Total":0.870,"Yesterday":0.137,"Today":0.198,"Power":1,"ApparentPower":3,"ReactivePower":3,"Factor":0.22,"Voltage":228,"Current":0.012}}'
2019-04-19 17:39:41.480 [WARN ] [eneric.internal.generic.ChannelState] - Incoming payload '{"Time":"2019-04-19T16:39:41","ENERGY":{"TotalStartTime":"2019-04-05T17:16:13","Total":0.870,"Yesterday":0.137,"Today":0.198,"Power":1,"ApparentPower":3,"ReactivePower":3,"Factor":0.22,"Voltage":228,"Current":0.012}}' not supported by type 'NumberValue'
2019-04-19 17:39:41.482 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.AM2301.Temperature' in '{"Time":"2019-04-19T16:39:41","ENERGY":{"TotalStartTime":"2019-04-05T17:16:13","Total":0.870,"Yesterday":0.137,"Today":0.198,"Power":1,"ApparentPower":3,"ReactivePower":3,"Factor":0.22,"Voltage":228,"Current":0.012}}'
2019-04-19 17:39:41.484 [WARN ] [eneric.internal.generic.ChannelState] - Incoming payload '{"Time":"2019-04-19T16:39:41","ENERGY":{"TotalStartTime":"2019-04-05T17:16:13","Total":0.870,"Yesterday":0.137,"Today":0.198,"Power":1,"ApparentPower":3,"ReactivePower":3,"Factor":0.22,"Voltage":228,"Current":0.012}}' not supported by type 'NumberValue'
2019-04-19 17:39:41.493 [vent.ItemStateChangedEvent] - mqtt_topic_steckdose_stube_Watt changed from 30 to 1
