Is the rule engine in Paper UI default “OR” or “and”?
I want to make a simple rule saying, if 1 of 7 smoke detectors is going off, i want to activate one “common smoke” switch.
I believe, though do not use the Experimental Rules Engine, that everything in the When section is treated as an OR and everything in the but only if… section is treated as an AND.
