unfortunately I did not find any information on this: I installed OpenHAB2 and used the Paper UI to create items linked with a MySensors node and a self made dimmer. This is working fine (display values in a chart after installing MySQL persistence and controlling the dimmer in hte HABPanel). However, now i would like to use the SmartHome Designer to create a rule so the dimmer gets switched on at sun set.
Problem: The items are not visible in the Designer, but I see the persistence files that I created to it must be the right folder? Do I have to create everything manually to have autocomplete and syntax check?
OH2 runs on armbian on an Orange Pi, Designer on arch linux, accessing /etc/openhab2 via NFS.
