In setup discovery found my chromecasts.
I’ve manually setup a temp sensor that’s populated via mqtt.
In paperui I can see the chromecasts but not the mqtt sensor.
In basic ui by default I can see the chromecasts…and if I specify the name of my sitemap, I can see my temp sensor.
How do I see both at once? I either need to know how to call the chromecasts from the sitemap.
Or how to get the mqtt sensor into the runtime config somehow.
What’s the method here.
